Old 03-20-2012, 08:34 AM   #1
godwisper
Default My first upgrades
so bought the mcpx V2 only 2 weeks ago and flew a bit last weekend and already thinking of upgrading some parts
btw I have already modded my tailboom to a 2.5mm solid CF rod.
1. KBDD extreme edition green main and rotor blades
2. Hyperion G3 CX 250mah batteries x 4
3. Parallel (6x) JST-PHR-2 Charge Cable
4. Xtreme canopy
I will get the MH swashplate end of month as already spent a fortune this month
was thinking of getting my order from http://www.fast-lad.co.uk as it seems cheaper than midland and has the hyperion batteries....
any recommendations ?
godwisper is offline        Reply With Quote
Old 03-20-2012, 08:53 AM   #2
ebeing
stock parts are really the best ones. If you want to have some fun with upgrades have at it, they usually wont improve your flying, just the deletion of your bank account.
The KBDD blades suck on my stock mcpx, others say they are better for brushless setups. I prefer the stock bullet blades, they are superior to KBDD.
What kinds of battery charger do you have?
130x | mCPX | mSRX | DX7S | mCPX BL
ebeing is offline        Reply With Quote
Old 03-20-2012, 08:59 AM   #3
godwisper
uhm that will make me re think about getting the blades....the canopy I need it cause I almost broke the stock one...
as battery charger I just bought a lipo charger/balancer from my LHS so that I can charge batteries in the field.
Old 03-20-2012, 09:38 AM   #4
bmitchell138
4. Xtreme canopy
The Hyperion 250's are good batteries and they are half the price of the eFlite batteries. Plus you can charge them at up to 5c. I like the KBDD blades. Mine have been through numerous crashes and they are still holding up well. And they are easier for me to see compared to the stock blades.
bmitchell138 is offline        Reply With Quote
Old 03-20-2012, 09:46 AM   #5
Hoghunter7mm
I also have the MH swash and notice that my blades track real well and it flys around better. You should also install the 6 inch solid carbon boom to hold tail better and more robust. I also swapped the orignal tail motor wires out for some cat 5 coated wires. I have 6 hyperion 250 and the 6 way paralell charger cable and like that setup very well. I also have the xtreme canopy and skids on it, so far so good. All and all I can say I just love this little bird and it has helped me to learn how to 3d a heli tremendously! Soon to be brushless as well. With the upgrades that I have done has transformed from something that I crashed constantly to something very stable and a great tool to learn with and she now looks more like a baby trex...
Hoghunter7mm is offline        Reply With Quote
Old 03-20-2012, 01:29 PM   #6
skeppley
dont bother using the kbdd tail rotor. The tail rotor that comes stock on the V2 is MUCH better.
The hyperions are a great choice along with the 6 plug charge cable.
Upgrades really arent needed, but are fun nonetheless.
I have 4 brushless mcpx's and only one has any bling on it Just cause i wanted to spend some cash..lol.
skeppley is offline        Reply With Quote
Old 03-20-2012, 01:46 PM   #7
godwisper
Thanks to all ...just ordered all of the above except the kbdd main and rotor blades for now....maybe will order next week with the swashplate but will see
any suggestion on what best settings to put in my charger to charge the 4 x hyperion 250 and the 2 stock flight 200mah ?
Old 03-20-2012, 02:54 PM   #8
skeppley
just add all the packs up and charge at 1C
250x4= 1000 plus 200x2=400, so 1400 or 1.4 amps
The hyperions can be charged at 5C, but i rarely charge mine at more than 2c for longevity. So if you are gonna only put the four hyperions on the charger, you can do:
250X4=1000. So 1 amp at 1C, 2Amps at 2C, or even up to 5AMPS for 5C with all four on there !!!
Old 03-20-2012, 11:53 PM   #9
MoparRob
4. Xtreme canopy
1. I really like my KBDD blades, I got the orange ones and like the extra visual indication and also believe they pop pretty well. My second favorite is the stock bullet blades. (I have not tried the KBDD tail blades Ive never had a problem with my V2 blades.
2 & 3 No experience with these
4. Extreme Canopy is so tough compared to stock. I've ran mine into concrete, fences, grass, trees whatever and it holds up great.
Also plus one on the aluminum swash I've had the Rakon on for some serious crashes and so far so good!!
MoparRob is offline        Reply With Quote
Old 03-21-2012, 12:31 PM   #10
Varc
I favor the white KBDDs, but thats just me.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Rakon NCPX-TDR, DX7. Rakon Rep.
Varc is offline        Reply With Quote
Old 03-21-2012, 06:45 PM   #11
MiataJohn
The only trouble with the Xtreme cano is that it's so tough you break canopy pins easier.
2x Stock mCPX, 1 B/L HP05 mCPX Blade 400 3x HS65mg, GY520, Align 425
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP,Parkzone T-28, All on Dx6i
AMA 732104
MiataJohn is offline        Reply With Quote
Old 07-31-2012, 10:47 PM   #12
R2Destroyer
What is a good tail upgrade......or in other words what set and where to get them? That seems to be the only issue that I am having. And when I go inverted I feel like there is not enough negative pitch to hob it back right side up. I usually end up crashing it cause I can't get it back right side up. It's really annoying. Sorry if this is the wrong thread to ask in.
R2Destroyer is offline        Reply With Quote
Old 08-01-2012, 01:46 AM   #13
UKHeliBob
Opinions on tails will vary. I use the single motor tail holder from astroid http://astroid-designs.myshopify.com...l-motor-mounts and a counter-clockwise main motor from the MCX2 http://www.ebay.com/itm/E-Flite-Blad...item415cd3bca9
As to the lack of negative pitch, try turning down all 3 servo links by a full turn each, or more if necessary. What you should do is to level your swash and check for zero pitch at mid stick (see the mCPX bible in the stickies) , but try turning down the links as a quick and easy fix.
UKHeliBob is offline        Reply With Quote
Old 08-01-2012, 05:25 AM   #14
Derfman
which way do you turn the links to shorten them?
Derfman is offline        Reply With Quote
Old 08-01-2012, 06:14 AM   #15
NCcraig
Clockwise.
Team Newb pilot
BL mCPx (HP06V2 motor/HP03 tail),130X with HP08 motor,Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, BeastX),DX7, AMA# 966513.
PM me about mCPX & NanoCPX BL conversions.
NCcraig is offline        Reply With Quote
Old 08-01-2012, 07:29 AM   #16
Coco66
Do you really need to post such a question to a forum and wait 49 minutes for an answer?
Try and find out!
(sorry NCcraig)
2 X Blade mCP X v2 ♦ night fly Blade mQX ♦ LadyMQX hybrid ♦ Blade 450X w/telemetry and Loc8tor ♦ Blade Nano CP X ♦ Compass Warp 360 w/AR7200BX, (2nd) Koby 40, DS92A+, DS95i, telemetry and Loc8tor ♦ Spektrum DX8/DX6i
Coco66 is offline        Reply With Quote
Old 08-01-2012, 07:31 AM   #17
R2Destroyer
Ah thank you. I will try this out. I did set zero pitch and what not. I am just Loki g for a tail that doesn't blow our as easy.
Old 08-01-2012, 07:45 AM   #18
SHYguy
I highly recommend the KBDD rear rotor, both for brushed and brushless. Together with a 2,5 cm longer and solid tail (Blade now sell a complete kit). Still, make sure you don'thave too much pitch (will make the tail turn). I find it to be better that the V2 rotor.
Also higly recommend the Turnigy Nano-Tech 300mAh batts from Hobbyking. Best there is from all I've tried. And low price too.
Main blades: Std. Blade bullet blades
Blade 2x nCPx Mild B/L, 2x mCPx dual B/L HP06V2, mCPx HP05S, 300X stockish, 300X Lynx/RKH/Wicked/Turnigy, 450X iKON, 6S T-Rex 450 V2, T-Rex 700E 3G BD3SX, Spektrum DX6i & DX8, Phoenix sim. 5 foamies. Way too many RC cars. Way WAY too little time!
SHYguy is online now        Reply With Quote
Old 08-01-2012, 07:51 AM   #19
UKHeliBob
What are you settings for negative and positive pitch Travel Adjust ? Setting them to a value that is too high can be a cause of tail blow out as can over-aggressive use of collective.
If the tail is blowing out you may need to adjust them to a lower value, say 70% or lower.
Old 08-01-2012, 08:10 AM   #20
koi-fish
UNless you're using an aftermarket frame. I got tired of snapping canopy pins. Since I started using extreme canopies, I haven't had to buy any more
/MSRX dbl bl, 5xMCPX, Nano, 1SQ, 2x130x, Gaui X2, 300x, DX8, Harley Road King
"It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa
koi-fish is offline        Reply With Quote
