| Atom 6HV Compass Atom 6HV Model Helicopter Discussion |
Do i have to set-up throttle endpoints w/ the HW70? nothing in the setup software about it [ unlike CC stuff]
http://www.hobbywing.com/uploadfiles...l/HW-01-PL.pdf
Bottom of second page. Section called "Throttle Range Setting"
Compass 7HV, SAB Goblin 700, Minicopter Diabolo, Mikado Logo 600, Synergy E5 RCHeliCanada.com - Compass Model - SAB Goblin - Synergy - MKS Servos - YGE - Kontronik |
Thanks!
Haha it helps to read instructions sometimes.
Two ambiguities remain for me though , - should the motor be plugged in for programming? - setting the endpoints, usual method is to set Tx to 25% then increase till beeps , does that apply? |
Are you using Vbar by chance?
#6 |
Yeah gotta have the motor plugged in to hear the tones
Sent from my T-Mobile G2 using Tapatalk
Compass 7hv - Fusion 50 - Trex 550 Stretched |
#7 | |
No, ar7200bx. Still wondering if motor should be plugged in during programming [no tone then] .
Here's a quote from another thread, its re. CC , just wondering if HW is same? Quote:
#8 |
Looks like it is ar7200bx and Castle specific. As far as I know, HW does not require you to alter the endpoints to detect high and low points. It's a simple as raising the stick to full position and then down to 0. Your throttle curves must be linear when you do this. I don't own or ever setup an AR7200BX so I am not 100% sure what needs to be done on the receiver side of things. But I can only assume that you have to bind the 7200 and when you do, please make sure your throttle curves are linear and throttle is at 0 when that happens.
#9 |
Formerly BarnStormer
7200bx will not pass any signal to the esc unless it see's 0% throttle. The HW esc can not set its endpoints unless the first thing it see's is 100% throttle. This is the only way I have found around the problem.
Unplug the throttle cable, fire up the 7200bx with a receiver battery, let is do it's thing. Go to high throttle then plug in the throttle cable and flight pack. Then you can set your throttle high and low points. Jason
"You can still call me Barn To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. " Team Compass USA ProStarHobby.com Scorpion Power Systems Last edited by Jason O'Connell; 03-26-2012 at 11:13 AM.. |
#10 |
oops, looks like i have one to many threads here,,,,,
ok ,s o i put the red wire back , NOTHING went according to the book beeps and tunes all over the place,,, BUT it now 'seems' to work , i plug in Bx [init.z] ,then plug in esc , i get BEEDLE-BEEP , then,, DUH-- DUH, DA DA which i presume is 2 long 2 short for 12S. But there is supposed to be finally a long beep [nope],, red lite off i think ,hard to see. Motor, TH , all work. So where am i? Another thing i'm not sure i have 'very soft start' , i have the motor disengaged it just revs up and down ,not sure i programmed that right , it seemed kind of inert when hooked up to the computer, program box just read 'connecting pc' software showed down load [[ using turnigy 1.62 & program box says v1.07 |
#11 |
Not sure why you cut the red wire
#12 |
Refusal to read chinglish
#13 |
You can and show setup the HW high/lo throttle limits..
Just power up the ESC with throttle stick at 100% (make sure you have a linear throttle curve configured i.e. 0 - 50 -100), when it beeps x2 move to low stick.. Done.. The motor shouldnt arm if you have the throttle at 100% when powered up but once it has confirmed the low stick position it will arm the motor.. I would recommend removing blades just in case... |
