Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 03-23-2012, 05:32 AM   #1
Euwan
Default Bec Wiring
Ok guys I am still so confused about wiring my bec. I know that if I am making the series connection on the esc itself the bec should be wired on the black lead of the esc. The only problem I am thinking is if I want to do any setup the motor will be active.
Now if I make up a series cable where would I wire the bec in that. I would want to make the cable so I would not have to connect it to the motor when I am doing setup, could someone make me a diagram or tell me if I am on the right path I really do not want to fry my electronics
Waiting for something special
Euwan is offline        Reply With Quote
Old 03-23-2012, 06:02 AM   #2
alexvan
The BEC has to be powered in parallel to the ESC. I have an EC3 connector on the wires coming to the BEC. So I can power the BEC without powering the ESC. Both the ESC and BEC wires are soldered (in parallel!) to the same EC5 connector. So normally I give power to both at the same time.
alexvan is offline        Reply With Quote
Old 03-23-2012, 06:09 AM   #3
Euwan
oh ok got it now just place a connector on the bec
Old 03-23-2012, 10:26 AM   #4
OnTheSnap
It's also common to run the BEC off of the first pack in series. This allows you to power the BEC and not the ESC. It also has the advantage of running less voltage to the BEC reducing the thermal load and improving reliability. After a flight you generally see less than 1% difference between packs.
MSH USA
Xnova
Xpert
OnTheSnap is online now        Reply With Quote
Old 03-23-2012, 10:48 AM   #5
gww528
plus... On some BEC's you get more amp draw at a lower voltage. If it fails less voltage going to the rest of your electronics.
gww528 is offline        Reply With Quote
Old 03-23-2012, 11:24 AM   #6
alexvan
I prefer connecting the BEC to both lipos. I prefer a balanced configuration in terms of load on the batteries.
Old 03-25-2012, 06:51 PM   #7
desertstalker
22V is going to fry your servos etc. just as much as 44 will, though perhaps with less smoke .
-DX8
Old 03-25-2012, 07:43 PM   #8
gww528
Ya, but I think just maybe you have a better chance of burning up less stuff at 22v than 44v... but your right. I know too many people have lost all of there electronics to a bad BEC letting all the voltage through... 7.2 volts is a safer.
Old 03-26-2012, 11:02 PM   #9
Tmiedema4
Wr Hercules bec enough said!!!!
Sent from my SAMSUNG-SGH-I717 using Tapatalk
Tmiedema4 is offline        Reply With Quote
Old 03-26-2012, 11:12 PM   #10
Long Nguyen
From an incident last week, my friend had a WR BEC installed incorrectly it was passing 22.2v + 6v ~28.2v to the electronics. Guess what, the vbar scarified first-in-line and saved all the other electronics.
So if you have decided to tap in the series connection and draw power from one of the 2 packs, the BEC's ground must be the same ground as that of the ESC!
Long Nguyen
Long Nguyen is offline        Reply With Quote
Old 03-27-2012, 07:47 AM   #11
AcidDrink
I run mine (WR Super BEC) from one lipo, just to be able to arm electronics without ESC - it's also useful for bench testing with one 6s pack. I don't fly hard, the difference between packs after flight is neglible.
BEC ground must be connected to packs ground and (I've seen a couple of people making this mistake) WR Super bec doesn't support buffer packs - they say they will have a small device to allow them very soon.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote
Old 03-27-2012, 08:34 AM   #12
Luisito
I've heard from other threads about this WR device coming soon. Can someone provide a link to it or at least a link to the announcement?
Team MikadoUSA - Luis
Luisito is offline        Reply With Quote
Old 03-28-2012, 04:18 AM   #13
windwizard
This is my basic setup Euwan,
this also allows the electronics to be armed without
the ESC being powered up.
windwizard is offline        Reply With Quote
Old 03-28-2012, 04:20 AM   #14
Euwan
What is that thing coming off your esc
Old 03-28-2012, 04:21 AM   #15
alexvan
What is the emcotec?
Old 03-28-2012, 04:21 AM   #16
Euwan
Yeah what is it
Old 03-28-2012, 04:32 AM   #17
windwizard
Originally Posted by Euwan View Post
Yeah what is it
It's a power switch with built in spark arrestor - check it out...
WIZ
Old 03-28-2012, 04:35 AM   #18
alexvan
Do you really need it? It's an other possible failure point.
Old 03-28-2012, 04:50 AM   #19
windwizard
Yes I suppose, but I like the refinement, it seems more proper.
Just gotta have a little faith!
Old 04-05-2012, 02:23 PM   #20
esmoglo
Any photos with the WR BEC installed?
Angelo
esmoglo is offline        Reply With Quote
