Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 05-18-2012, 02:50 AM   #41
smsodhi
Gerd recomends White or Yellow for good visibility.
It looks great, faxxe and I look forward to seeing yours OICU812 when its done.
Mine is still down, waiting for the Radix V2 to come.
TRIABOLO P800 Kosmik HC3-SX 255/256
DIABOLO 4530 Kosmik HC3-SX 690/105 255/256
Futaba 12 FG
smsodhi is online now        Reply With Quote
Old 05-18-2012, 08:56 PM   #42
Dumbthumb75
Originally Posted by kevinbj1 View Post
How do you like the motor? Does it have great power ?
Sorry for the late reply, had to get some more flights on it before commenting...
I like the Xera 4035 alot. It seems to have more power than the Pyro, however it gets a little warmer. Still no problem holding my hand on it after a flight. It should be said that the TDR sports a naca duct, Diabolo not.
No issues with the Jive.
Thinking of getting a Xera 4530 or Scorpion Ultimate for the Diabolo, and put the 4035 in the TDR...
minicopter Diabolo, Henseleit TDR, MA Spectra-G, Raptor 50T
Futaba 2.4 GHz
Dumbthumb75 is offline        Reply With Quote
Old 05-27-2012, 12:06 AM   #43
Mercuriell
ID:	319920   Click image for larger version
ID:	319921   Click image for larger version
ID:	319922   Click image for larger version
John
Mercuriell is offline        Reply With Quote
Old 05-27-2012, 12:07 AM   #44
OICU812
NICE John!!!
I got mine on bench in its super tiny box but need the damned time to start building! Still waiting for canopy to arrive from overseas, but I am pretty anxious here!!
OICU812 is offline        Reply With Quote
Old 05-29-2012, 02:51 AM   #45
smsodhi
WOW John. How do you get it to make thoses stripes on the lawn? Wimbledon is coming up soon. That is really low, and FAST.
Futaba 12 FG
Old 06-02-2012, 01:31 AM   #46
OICU812
Default My "Naked Diabolo" :)
Well here it is "NAKED" for now till I get a canopy.
Overall everything went smooth on build, other then some clarifications needed so thanks to John and Helicraze indeed.
Old 06-02-2012, 02:30 AM   #47
jhunter
Congrats! Looks great. I've been meaning to try some matt blacks myself.
TDR, Srimok N x 2, Banshee 31, avant aurora, Dune!
jhunter is online now        Reply With Quote
Old 06-02-2012, 04:48 PM   #48
Mercuriell
Looks great Shawn, like the Rx mount and those matt blacks do look wicked!
John
Old 06-02-2012, 06:42 PM   #49
whytlotus
You'll probably need to pull the antenna leads back until the exposed part of the antenna is even with the end of fingers on the mount. As it is, they will hit the canopy. You might need to bend it down some too. Mine only protrude about 10mm outside the frame and just clear the canopy. It'll be a little trial and error once you get your canopy. Looking good.
whytlotus is offline        Reply With Quote
Old 06-02-2012, 11:25 PM   #50
OICU812
Thx, for now it's good as you mentioned once I get canopy I'll fit it all to that for a clean look. Also one other thing, I did need to sand the main shaft quite abit to fit the swash on, much more so then any other kit I've ever had, you fellas run into that as well?
Rain today so could not even get any more time on it, I am also waiting for pinions etc so I can utilize the helijive and Vbar gov etc..
Old 06-03-2012, 12:15 AM   #51
Dumbthumb75
I put the swash in the oven for 15 mins., in order to expand it that little bit extra for easy fitting.
Futaba 2.4 GHz
Old 06-03-2012, 12:58 AM   #52
OICU812
And the ball stayed "larger"? How is that good for te retaining glue that holds bearing in though?
Old 06-03-2012, 04:20 AM   #53
Mercuriell
My swash was fine - most likely the mast was slightly out of tolerance - just a hundredth of a mm grinding down the shaft can cause binding
John
Old 06-03-2012, 06:33 AM   #54
whytlotus
Also one other thing, I did need to sand the main shaft quite abit to fit the swash on, much more so then any other kit I've ever had, you fellas run into that as well? .
Mine fit fine. The only fitting I had to do was extend the 4 motor mount slots on the frame forward about 1mm. The pinion was always engaged until I did this.
Old 06-03-2012, 06:54 AM   #55
helicraze
My main shaft was tight on the bearings but swash was ok.
helicraze is offline        Reply With Quote
Old 06-03-2012, 07:28 AM   #56
Dumbthumb75
Just heated it to 70-80 degrees C, and put little bit of grease on top of mainshaft. Slipped right on, no issues. Could not get it entered when cold, no way.
The slight expansion of the swash ball helped me line up the swash to the mainshaft, in getting it going. The tolerance was so tight that the swash ball had to be perfectly lined up with mainshaft, but it is loose enough not to cause binding.
Just a few hundredths of a mm...
Futaba 2.4 GHz
Old 06-04-2012, 07:27 PM   #57
johnnytango
Pictures of my "Diabolo"... before the crash. Pilot error!!
ID:	322059   Click image for larger version
ID:	322060   Click image for larger version
ID:	322061   Click image for larger version
ID:	322062   Click image for larger version
JR Sylphide E12, JR Vibe SG E12, JR Vibe SG E12 "Hiroki Ito Edition", JR Vibe SG Nitro, TDR, Minicopter Diabolo, SAB Goblin 700, SAB Goblin 500, Hirobo 450 Embla. RADIO: JR DMSS XG8
johnnytango is offline        Reply With Quote
Old 06-05-2012, 02:21 AM   #58
OICU812
Nice Jonny, you rockin a XG8 hey? Cool !
Old 06-05-2012, 07:37 AM   #59
marcosp
Is the double boom support part of the kit or a mod you made? I always saw only one fixed to the center and pretty high.
Marcos
Banshee #27, 2x TDR, Diabolo, JR Sylphide E12, Voodoo 600, Voodoo 400, Avant Aurora 90N, Rave 450, Gaui X2
marcosp is offline        Reply With Quote
Old 06-05-2012, 09:20 AM   #60
johnnytango
Thanks Shawn. Had to change all my receivers for this radio.
Dug into my 2nd kit for parts, had the same problem with the main shaft. Swash plate is tight going up and down along the shaft. Put end of main shaft on cordless drill with chuck, spun it with fine grit sandpaper wrapped around the shaft. Smooth now.
Marcosp,
Double boom supports are part of the kit.
