| Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others |
JUst wanted to see what everyone else is using for Li-Po charging aside from less than adequate 'factory' chargers. Am looking at getting a good hopefully low priced charger for mostly 3s packs but would also love to have adaptability for other battery sizes. My daughter has a ton of 1s for her heli and has had no problems with the Celectra charger she has, but it is ageing a bit and I think she is ready for a bigger heli anyways, so I thought now is the time (plus that gives me a perfectly good exusse for the wife to authorize the purchase
Doing nothing is very hard to do, you never know when you're finished Blade 450 3D, SR (TT tail in progress), mCPXv2, Carbon Cub SS, Dx6I |
Looks a lot like mine. Only mine charges more then 3 types of batteries like nimh and such. I Paid 65 bucks for mine. It is great because mine came with all the hook ups needed like that one there. Buying leads after the fact can get pricey. Only thing is it did not have any that would work with Blade Heli's. Be it micro or bigger. So you will have to solder up some leads. I still am charging my 1s lipos on my Celectra MSR and MCPX chargers though. I just use my balancing charger for my Gen ace 800 3s 20c batteries. Seem to do the job and the charger even has a auto charge feature to stupid proof the process.
Team Newb pilot BL mCPx (HP06V2 motor/HP03 tail),130X with HP08 motor,Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, BeastX),DX7, AMA# 966513. PM me about mCPX & NanoCPX BL conversions. |
I use two of these chargers: http://www.hobbyking.com/hobbycity/s...idproduct=7028
on this power supply: http://www.hobbyking.com/hobbycity/s...00v_120v_.html I LOVE this setup. The chargers have the balance connections built in so don't have to worry about carrying or misplacing those. I can charge 2 3s batteries at once, or 3 mcpx (balanced) and 1 3s at once. Or 6 mcpx balanced at once.
130x - 300x - Goblin 500 - mCP X BL - mCP X HP08s Double Brushless |
Here is my setup:
http://www.helifreak.com/showthread.php?t=396586
Blade 300X, mCPX, FPV Raptor, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX7s. |
#6 |
Progressive rc. Is the place you want to order from. 206 b is your ticket
rex 250 se and 450 sport Mcpx v2 msr x 130 x dx 6 i |
#7 | |
I have a Parallel board with it and can charge 4x 3s 2200mah batteries in about 30 minutes.
William Alees Rush 700-Kosmik 160A + KDE 700XF-495 Synergy N5C & E5-600 Protos 500 |
#8 |
Im running an Ecopower Electron 65 AC/DC from Amainhobbies.com for 49$ it's MUCH better then the factory charger and it does what i need it to. Balance, discharge, storage charge, fast charge, ect..ect.. I dont mind waiting 2 hours to charge 4 batteries.
Eat. Sleep. 3D -Markus |
#9 | |
![]() Quote:
Just kidding. Very nice though. You mind if I ask how much $$ you got in it? Might be alittle over kill for me but interesting none the less
#10 |
Oops, I left my secret light in there.. Thats actually my discharge light. For a long time imax b6 was my only charger and it would discharge at some pitiful rate, where as the 2 lights discharge at around 10amps or so. In case I crash and can't get through all of my batteries, I use that because I don't like storing them with full charge. You have to manually watch the cell voltages closely while doing this as you don't want to over discharge the battery. With 2 lights, I can take a fully charged 2200mah battery down to 3.85v/cell in about 15minutes. The battery does not heat up at all, and the rate 3x slower than if you were flying, so it's safe for the battery.
Anyway, total cost for my setup is listed in that thread. $50 for the 200watt charger from hobbypartz.com and $17 in parallel charge cables. I already had the power supply, tool box, and assorted 4mm banana sockets and plugs so both the 200watt sky charger, and the 50watt imax b6 can be hooked up at the same time. But if you were to buy those (PS, and various plugs), it would be less than $20. I also use one of the 5V leads from the PS for an additional fan that I can hook up, although the PS and charger both already have internal fans.
#11 |
not bad really. And why have I never thought of using a light bulb in that way. It's amazing the simple things you never think of, I guess. Being a mechanic, I got tons of those laying around. I'm gonna still that idea if-in ya dont mind.
