Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50
Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters
Old 03-24-2012, 07:59 PM   #1
cruzroy
Default I was flying today....And i got Problems!!!!!NOW I GOT A 2.4 CONVERSION...Watch video
I got a Raptor 30 v1, all i want to do is sell it so i can save for a bigger bid, so i was fling today and she is very clean, like new bird....all trim out, but i get (Raptor 30 with Epilepsy!) she fly good an at random times al servos twitch, even throttle, i dont want to sell her till i know its safe.....so i need help, im still a noob and i never seen this before, ive had 1 servo wiggle before but not all,,,,any help would be great.....watch the video and see it wiggle, and she throttles up quick sometimes to,,,,
this is what it has
Raptor 30 V1
tt 36 pro
align 2 in 1
all futaba servos
GY401
15% nitro
sab cf blades
72 MHZ futaba radio T6XH and futaba rx
i was woundering if the 72 MHZ is no good with the 2in1 should the anttenna go away from it?
my raptor 30 v2 has 72MHZ radio to but it is a 7c radio with same equiptment, and i dont have a problem
hope some one can help
daddy needs a gasser..........as always...thanks guys
figured i got this corona DIY kit for 16 bucks......i think i will try it.....next i will attemt to fly my Raptor 30
[/YOUTUBE]
[/YOUTUBE]
cruzroy is offline        Reply With Quote
Old 03-24-2012, 09:10 PM   #2
johnbs8
Check n make sure none of your wires are cut open from rubbing on the frame... ive seen that before and thats what the cause was. Yours might not be that but i would start there.
Titan X50B : YS56sr GP Pipe, Tracx600 FBL, AR7200BX, Ds610 X4, DS650, Pushglo and compass 615mm FBL
Titan X50T : Ys56sr SAB-55 Pipe, Tracx600 FBL, AR7200BX, DS8717 X3, BLS251, Pushglo Radix V2 625mm FBL
johnbs8 is offline        Reply With Quote
Old 03-24-2012, 11:49 PM   #3
tr911
Could be interference from neighboring radio waves..
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote
Old 03-25-2012, 09:05 AM   #4
johnbs8
also try and not point that antenna at the heli. that will make a dead spot
Old 03-25-2012, 11:42 AM   #5
burntclutch
Cool
Check tail boom support rods ( Tight ) , Check drive belt for stretch , can even be the fan on the motor , but as said .... pointing the antena is a deadly sin
Whoever invented the term “foolproof” underestimated the ingenuity of fools.
burntclutch is offline        Reply With Quote
Old 03-25-2012, 12:08 PM   #6
cruzroy
i bought ths girl used and it has magnets on the fan....what are they for????
Old 03-25-2012, 12:29 PM   #7
olliedamm
I can't hear anything wrong over the background music. I agree with the above, pointing antenna at the heli is not a great idea, but should not lead to any issues at such short range. The magnets in the fan are usually for a governor sensor, which is used to keep the rotor rpm constant at a pre-programmed level. Twitching servos particularly on the tail can be caused by static on the tail belt, this can be exacerbated by tightening the belt and using a carbon fibre boom. If that is the case, try a silicone spray on the tail belt as first remedy, if that does not work, try grounding the tail boom to the engine block with a wire.
olliedamm is offline        Reply With Quote
Old 03-25-2012, 01:29 PM   #8
varacer
more than likely the problem is in the reciever. I had the same problem before I switched to 2.4 and it was in the reciever. Try a difff one to see.
varacer is offline        Reply With Quote
Old 03-25-2012, 06:57 PM   #9
JeffKollin
Remove the 2n1 and see what happens
JeffKollin is offline        Reply With Quote
Old 03-27-2012, 12:57 PM   #10
YSRRider
I have never heard of anyone having to ground the boom to the engine block or this theory of static from the tail belt. Please post another thread to support this topic. I would like to educate myself further.
I do not advise spraying anything on the belt. The common practice on helis for years has been to run everything dry. Lubricants attract dirt which will wear parts out faster.
YSRRider is offline        Reply With Quote
Old 03-27-2012, 01:31 PM   #11
tr911
+1 on the lubrication. I learned the hard way. Now I don't put any oil or grease on any of the bearing or shims..
Old 03-27-2012, 04:24 PM   #12
darryl123
try to move the antenna around ,rerout the antenna away from metal and servos and make sure there is no metal rubbing and all the bearings are good. 75mhz is very picky about interferance.
if you cant figure it out im close by and can take a look at it for you.
raptor 90 fbl
raptor 50
raptor x50 fbl
raptor e620 fbl
darryl123 is offline        Reply With Quote
Old 03-27-2012, 06:38 PM   #13
YSRRider
Your bearings should be greased with a bearing greaser. Any grease that seeps out, should be wiped away after a day of flying. Your pitch sliders should get a drop or 2 of Tri-Flow or perhaps dry graphite and that too should be wiped clean at the end of the day and re-lubed before the next day of flying. Too many flying pigs out there.
Old 04-03-2012, 03:22 PM   #14
pete best
Here's a few
There are many more
http://www.helifreak.com/showthread.php?t=378259
http://www.helifreak.com/showthread.php?t=61205
http://www.helifreak.com/showthread.php?t=368539
Greg Short
Compass Field Rep
Compass Odin 90, Compass Atom 5.5, Compass 3d+
Trex 700E
pete best is offline        Reply With Quote
Old 04-03-2012, 07:42 PM   #15
rstekeur
How do you really feel? lol
Blade MCP X, Blade SR, Blade 450 3D
Trex 450pro, Trex 500, Trex 600
Titan Raptor 50
rstekeur is offline        Reply With Quote
Old 04-04-2012, 06:49 AM   #16
cruzroy
Default do you think the raptor is building up that much static
do you think the raptor is building up that much static in the boom.....ho would you test it.......run it without blades
Old 04-04-2012, 07:43 AM   #17
pete best
2 of the easier fixes I've seen are connecting a ground wire on the tailboom. Connect it at the tail rotor end, then at the drive end, and then to the engine, all in series. It doesn't have to be pretty for testing purposes. Also graphite from a carpenters pencil. run it on the outside of the belt all the way around. Seems to act like a graphite lube without oiling things up.
Greg Short
Compass Field Rep
Trex 700E
Old 04-06-2012, 06:13 AM   #18
cruzroy
Default long!!!!!!!!!!!!!
Long conversion from 72 mhz to 2.4 Ghz....NOOB Attemp
