Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 03-25-2012, 05:16 AM   #1
Shanes
Default Replacing Flybar 450 3D
Hiya - replacing flybar for the first time - one of the weights is stuck on even with screw removed -the other one just slid right off easily. How best to get it off?
So many thanks for any help!
Shane
Shanes is offline        Reply With Quote
Old 03-25-2012, 07:40 AM   #2
thunder6
shane,
If i understand you right, You have the flybar off right ? If so you can try to heat alittle bit might be some lock tite holding it up,
I had the same problem But mine was a birr where the screw set on the bar , I just grabbed bar with pliers and pulled on the wieght.
___________
blade450, gaui x5 (soon)
dx6i, phoenix sim
thunder6 is offline        Reply With Quote
Old 03-25-2012, 07:47 AM   #3
Shanes
Thanks!
I have the flybar off and even while holding it with pliers and yanking on the weight it isn't budging at all. I've even tried two sets of pliers - one on the bar and one on the weight and all my super strength - stuck! Guess I'll try some more and worst case just pick up another weight. Ack!
Thanks again
Old 03-25-2012, 12:26 PM   #4
Shanes
All good - a hammer did the trick!
