Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 500
Atom 500 Compass Atom 500 Model Helicopter Discussion
Old 03-30-2012, 10:18 AM   #61
Ermac
I figured out today my problem is not with the esc but the SK720.
Coz I tried different reciever it arms fine.
Ermac is offline        Reply With Quote
Old 03-30-2012, 08:52 PM   #62
Jeff_Barrett
A bad unit is possible - but I've never seen a throttle problem to date with the SK-720 itself. The only time I've seen it was due to settings either in the SK-720 or ESC and were resolved.
Have you contacted the folks you purchased it from?
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
Old 03-31-2012, 10:33 AM   #63
Ermac
Problem Solved!
Since the problem only started occuring after throttle setup, I thought maybe I need to arm the ice 100 before.
So I redid my control stick scaling
1) found under utility - Reset Control Stick Scaling.
2) Set control Stick Scaling -> So u got a fresh start calibrate on the control stick. make sure u did stick scaling properly.
3) Arm the motor
4) Then finally do the last setup which will fiddle with ur high stick and idle (Which seems to me was what was causing my sk720 to be confused and never see high or low sticks)
Old 03-31-2012, 10:48 AM   #64
Jeff_Barrett
Excellent ... so you have the CC working with the SK720 now?
Well done!
Old 04-01-2012, 04:32 AM   #65
chopstick
Fine.
Have a nice flight. Or better, a thousand of them.
LOGO 400SE : Skookum SK540, Scorpion 3226 1230kV
SJM180 : Tarot ZYX
Rigidheli.com: The place where Dutch Helipilots meet
chopstick is offline        Reply With Quote
