Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Old 03-28-2012, 08:43 AM   #1
twentyafter
Default Damage after crash....
My hobbywing 40 amp ESC was damaged in a crash. If it could be repaired I probably still wouldn't use it, but I am curious if it could be repaired as it looks like the only damage is to one of the capacitors and some impact damage to the heat sink.
What do you guys think?
Name:	2012-03-27 21.30.15.jpg
ID:	302748   Click image for larger version
Name:	2012-03-27 21.30.25.jpg
Team Lynx Heli
Warp 360 / Chaos 550 / 130X
AMA # 971952
twentyafter is online now        Reply With Quote
Old 03-28-2012, 03:51 PM   #2
nparker13
I had an Align ESC that the capacitor broke off. I got the same size and resistance at radioshack and soldered the puppy right back together. Cheaper to try than than to buy a new ESC. My only worry and I'm not very knowledgable in this area is did it cause a short and messed up other parts of the ESC. Either case, I wouldnt hesitate to solder it together.
nparker13 is offline        Reply With Quote
Old 03-28-2012, 03:55 PM   #3
wbefield
I soldered new caps on my YGE 60A. As long as you you the same rated caps and there is no other damage to the ESC board you should be fine.
William
Alees Rush 700-Kosmik 160A + KDE 700XF-495
Synergy N5C & E5-600
Protos 500
wbefield is online now        Reply With Quote
Old 03-28-2012, 05:45 PM   #4
twentyafter
Great, I appreciate the replies.
Set from my Samsung Galaxy S using Tapatalk
Team Lynx Heli
AMA # 971952
