Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 03-28-2012, 09:33 AM   #1
Groucho_
Default Best alternate bolts for tail blade grips
It's a known fact that the tail blade bolts are too short - they don't engage the nylon part of the locknut...
I got myself three different types of bolts, and these are a perfect fit both lengthwise and diameter-wise:
http://www.modelhelicopters.co.uk/m3...shouldere.html
They even have a shoulder which seems to be made to measure for the TDR grips and spacers, and the Radix blades.
Much better that having the bolt threads making contact with the blades I'd think...
Groucho_ is offline        Reply With Quote
Old 03-28-2012, 10:24 AM   #2
Heli G
Interesting...I have three kits and none of them have tail bolts that are too short. So how many kits have this problem?
Heli G is offline        Reply With Quote
Old 03-28-2012, 10:32 AM   #3
Groucho_
Well, you're the first I read about who has correctly sized bolts...
Old 03-28-2012, 11:38 AM   #4
Dumbthumb75
Same problem here. I replaced them with bolts I found in my R50 parts box.
http://www.helifreak.com/album.php?a...ictureid=69725
They're fully threaded, btw...
minicopter Diabolo, Henseleit TDR, MA Spectra-G, Raptor 50T
Futaba 2.4 GHz
Dumbthumb75 is offline        Reply With Quote
Old 03-28-2012, 12:35 PM   #5
Egroeg
My bolts are short too...
But I used a cutting disk on the dremmel and made the bolt thinner till the screw sits further into the thread...all good to go !
No Pitch...No Fun!!!
Egroeg is offline        Reply With Quote
Old 03-28-2012, 02:34 PM   #6
jhunter
Default MIne are fine too
well over 100 flights
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote
Old 03-28-2012, 04:30 PM   #7
richardmills
Got my kit nov 2011 and mine are too short. I just used some threadlock.
richardmills is online now        Reply With Quote
Old 03-28-2012, 06:53 PM   #8
mkovalcson
I got mine in February and I reversed the nuts and screwed straight into the nylock.
Henseleit TDR, Synergy E5, MSH PROTOS 500, 300X
Jeti DS-16, Skookum, Kontroniks
mkovalcson is offline        Reply With Quote
Old 03-28-2012, 11:17 PM   #9
Vinger
My first kit arrived with the short bolts, second one is fine. You will need galvanized 3mm hexagon 12.9 shank bolts and the correct length is 20mm. my first kit (2009) had bolts of 18mm supplied. If you can't get them galvanized a normal 12.9 steel bolt will do, they just tend to rust a bit.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC
Hyperion 1420, Mega Power Gemini Chargers! JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 03-29-2012, 12:40 AM   #10
Stolla
that's no good if it doesn't have enough thread, replace them if too short.
Old 03-29-2012, 07:47 AM   #11
ZuvieleTeile
Mine have been very tight, almost too short.
I took longer ones and cut them to fit
Kind Regards ZT - TDR, Logo-400SE
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is online now        Reply With Quote
Old 03-29-2012, 09:21 AM   #12
mkovalcson
How's this? $11 for 100 bolts I'll need to order another 48 TDR's
http://www.amazon.com/dp/B00598DL7W/ref=biss_dp_t_asn
Or $40 for 10 bolts in SS. Seems a bit pricey to me.
http://www.amazon.com/dp/B00137HPRK/ref=biss_dp_t_asn
I think these are the winners!
Metric Zinc Plated Alloy Steel Socket Head Cap Screw, Hex Socket Drive, M3-0.50, 20 mm Length (Pack of 100)
http://www.amazon.com/dp/B005A0OIGC/ref=biss_dp_t_asn
Old 03-29-2012, 09:32 AM   #13
Groucho_
Mark, none of those have shoulders...
If you want the best for your TDR, then you have to go with the ones I mentioned...
Old 03-30-2012, 02:22 AM   #14
Danny_Swe
I bought these ones, will mount them just about now:
http://www.fast-lad.co.uk/store/av00...w-p-12153.html
TDR, 550E, 450Q | VBar, YGE, DX8 | Olympus OM-D
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote
Old 03-30-2012, 02:57 AM   #15
Groucho_
I have those also... Not as good as the ones I eventually used and mentioned in my first post... I didn't use them.
Old 03-30-2012, 06:51 AM   #16
Chris_M
Here's a 18.8 stainless set of 20 for $5.56 partially threaded.
http://www.mcmaster.com/#92855A319
Chris_M is offline        Reply With Quote
Old 03-30-2012, 07:00 AM   #17
mkovalcson
Very nice!
Now add this one for a higher quality Jesus Bolt and the order is complete
http://www.mcmaster.com/#91290A164
Old 03-30-2012, 08:34 AM   #18
ZuvieleTeile
I take some of those Mark. . .
Old 03-30-2012, 08:42 AM   #19
mkovalcson
You are welcome to some.
To bad there wasn't a communal area like a penny jar to put stuff like this that comes in bulk and you recieve a quanity of parts that you will never use!
Old 03-30-2012, 08:51 AM   #20
Dumbthumb75
Very nice!
In this example, I belive the 18-8 stands for the quality/ "blend" of stainless steel. Not tensile strength...
Futaba 2.4 GHz
