| mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions |
I just put in the convertor and esc in along with the main motor, everything seems to work but sometime the motor wont spin up all the way, even at full throttle. I soldered the yellow wire to the back on the resistor that the instructions say and the 2 others to power. did I do something wrong?
If you can get the motor to start. Most likely you connect every thing to
the right place. If you are using the 3 pin connector, get rid of the connector and solder it to the ESC directly. Double check your solder spot. |
