Old 03-29-2012, 03:49 AM   #1
augur
Default Tail servo jerking even in setup mode
Hi.
My tail servo (BLS251) is jerking even when I am in the setup mode to set the max. travel. Is that common or is there a electrical problem? I can understand when this happens in the normal flight mode because of the algorithm, but in setup mode?
Cheers,
Nils
augur is offline        Reply With Quote
Old 03-29-2012, 05:08 AM   #2
RC Mike
What voltage? The BLS251 is a 4.8 –5v servo so if you are running more than 5v that would be the problem.
RC Mike is offline        Reply With Quote
Old 03-29-2012, 05:11 AM   #3
augur
At exactly 5V. The jerking is periodically round about 3-4 seconds. In flight everything is fine...
Old 03-29-2012, 06:02 AM   #4
insertnamehere
I have a MKS BLS990 on the tail and when I'm in setup it kicks randomly every few seconds. Doesn't happen outside setup, and no problems in flight.
T-Rex 500:
I2 - Head, Tail, Bearing Blocks, Bottom Plate
Neu Motor
1706/1.5Y, Kontronik Jive 80LV with JLOG2
Skookum SK-720, DSMX Satellites, JR3517MG and MKS BLS990 servos
insertnamehere is offline        Reply With Quote
Old 03-29-2012, 06:18 AM   #5
Jamesppp
I've been operating a couple BLS 251 servos for around 2 years on 6v.
I thought that Futaba had even OK'd this.
I "borrowed" a WR voltage step down from one heli to put on another. Much later I found the step down in bag I keep my tach, temp guage and other accessories in.
I realized that 2 heli's with 251's on the tail had been operating on 6v for a while.
Found out later that a lot of guys were doing the same thing so I never changed it.
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 03-29-2012, 08:51 AM   #6
RC Mike
Old 03-29-2012, 01:39 PM   #7
georgi UK
=] Futaba have rated the BLS251 @ 6v, mine is into its 3rd season at this voltage, works fine.
it does tick away to itself in setup mode, this is normal.
georgi UK
georgi UK is online now        Reply With Quote
Old 03-29-2012, 01:42 PM   #8
NRPY
Running my BLS-251 at 6V too.
NRPY is offline        Reply With Quote
