Old 03-30-2012, 12:34 AM   #1
gfdimopo
Default How to adjust BeastX pot1 safely
Hello guys!
Helicopter Specs:
Align 500mx
Align 70 Esc
Lipo zippy 2650 30C
Servo DS510M+DS520
BeastX with 3M tape
My question is how can I adjust properly the pot1 in beastX.
In the past I try to adjust and my helicopter roll over from the sky and hit at the ground.
Is there any safe guide to undestand that I have the optimum setting in pot 1!
Now my setting is at 8:30 (9 o clock is center- Default value)
gfdimopo is offline        Reply With Quote
Old 03-30-2012, 09:47 PM   #2
aerocal
Its kind of hard to understand what you are asking.I mean how is the heli acting that makes you want to change the swash gain?
If you get it a bit high you will start to get hunting/oscillation.A bit low and it will get drifty.
How much did you turn the dial to get a radically different reaction from one flight to the next? You really only need to turn it like one blade width at a time and recheck.
"Roll over from the sky and hit at ground"
I really dont see a gain adjustment making a radical change like that unless you turned the dial a whole bunch all at once.Even then...
Too many helis & Too many planks
Lots of DX radios & A couple Futaba radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is online now        Reply With Quote
Old 03-30-2012, 09:50 PM   #3
Bob O
Originally Posted by gfdimopo View Post
SNIP
http://www.helifreak.com/showpost.ph...99&postcount=1
SPARTANRC - Forum Support
Warp360
Bob O is online now        Reply With Quote
Old 03-30-2012, 10:55 PM   #4
KC36330
Best way i've found to set cyclic gain is by doing a hard cyclic rock in hover at your max head speed. I turn it up till i get a bobble after letting the stick back to center after the hard rock, then back it down till the bobble is gone and you're all set.
JetCat USA Rep / KingTech Turbines Rep
KC36330 is offline        Reply With Quote
