Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 04-01-2012, 09:28 PM   #1
TorqTube
Default Will bigger main blades be more stable?
Looking to get the Fusion FBL kit. Now I do forward flights, basically taking it easy.
Will bigger main blades, like 640mm Edge blades work, if that is the longest they make?
If I go bigger on the main blades, Will I need bigger tail blades as well? What size?
If someone can some that up for me that would be great!
By the way I most likely would use a 12 cell lipo, if that helps.
Lastly, can I go with 623 mm main blades going 6 cell lipo? what size tail blades?
Thanks HFs
Starting All over Again! Been out of the Hobby For a While!
TorqTube is online now        Reply With Quote
Old 04-01-2012, 09:43 PM   #2
Slyster
I love the 623mm edge blades. 640mm are hard to find.. Edge doesn't make them nor do most brands.
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is offline        Reply With Quote
Old 04-01-2012, 10:12 PM   #3
TorqTube
What size tail blades? If I do go with 623 mm main blades.
Will 6 cell be efficient to swing those blades?
Thanks Slyster
Sent from my DROID RAZR using Tapatalk
Old 04-01-2012, 10:17 PM   #4
Slyster
No.. 6s uses 550mm blades only!
What motor and ESC do you have?
Pete Team Outrage.
Old 04-01-2012, 10:23 PM   #5
TorqTube
I don`t have any electronics..I was thinking of going scorpion w/ CC ESC and Outrage cyclics and tail.
What do you think?
Old 04-01-2012, 10:27 PM   #6
Slyster
Sure.. but before you buy anything you need to decide how you are going to run the heli... since your starting from scratch I'd suggest a 12s machine running 623mm blades.. its just so much more fun than when I was on 6s and I get 7 mins of flight time with Gens Ace 4000mah packs. Look at the sticky 'fusion 50 setups' to see what others are running.
Pete Team Outrage.
Old 04-01-2012, 10:31 PM   #7
Ah Clem
Is it flybarred or FBL?
I can only comment on the FBL version, but it is pretty darn stable.
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
Old 04-01-2012, 10:31 PM   #8
TorqTube
Yes definitely going 12s setup and running 623mm Edge blades..
I will look through the setup sticky..
Old 04-01-2012, 10:33 PM   #9
TorqTube
FBL version going w/ Skookum 720 system
Old 04-01-2012, 10:45 PM   #10
AeroMattics
Can't speak for the skookum, but you'll love the 12s Fusion swinging 623s!
Compass 7HV
Compass Atom 500E
Outrage Fusion 50
AeroMattics is offline        Reply With Quote
Old 04-01-2012, 11:54 PM   #11
backburner1955
Any bigger than 95mm tail blades on the Fusion 50 and they will hit the ground. You would need to add extra protection on the vertical fin.
AMA# 982814
backburner1955 is offline        Reply With Quote
Old 04-02-2012, 01:03 AM   #12
Carapau
Location: God's own county. Ay oop lad, tek care lambs ont road
The longer the blades the more stable the heli without doubt. Although the Fusion is sold as being able to swing 640s, as Sly stated you will find it hard to get some and the increase in stability over the 623s is probably barely noticeable. I fly 623s and as others have stated, the heli is as steady as a rock with those on, especially when coupled to a good FBL controller like you are proposing to use.
If using 623s then the 95mm tail blades are more than sufficient. If ever I get a blow out (can't remember my last one) then it is because I have screwed up.
So, to cut a long story short, what you are proposing will be an excellent set up:
12s (do this from the start and it will save you money in the end)
623mm mains/95mm tails
ESC rated at 80A or over (new CC appear to be good news now).
Scorpion 4025 (I don't think there is any need to get anything above this unless you are a complete 3d nut and just want insane power). The 4025s have bags of power as is, plus your gear train well stand up better to it in stock form.
Torq servos.
To make it the mutts nuts I would consider perhaps moving to Vbar and a compatible ESC because the Vbar gov is fantastic (not sure if the Skookum has one and if so how good it is). If you did this I can see no reason to upgrade anything in the future.
Rush 750, Vbar, 9188, BLS157HV, Kosmik 160, 4525 Ult
Fusion 50, Vbar, 9188/80s, Helijive & Quantum 4135 motor,
Mini Protos DS95s/95i, Ice Lite 50, mini v
Trex 450 Pro DS95/95i, Mini V, RJX head, Ice 50 Lite, 6s 2221-2010 DX18
Carapau is online now        Reply With Quote
Old 04-02-2012, 07:05 AM   #13
TorqTube
Great info!
Old 04-02-2012, 10:26 AM   #14
Ah Clem
"If ever I get a blow out (can't remember my last one) then it is because I have screwed up."
I agree-I cannot get mine to blow out under any circumstances.
I am running Compass 615 main blades and KBDD 96mm EE Tail Blades (Bright Orange, of course).
KBDD-Team Pilot
Old 04-02-2012, 10:29 AM   #15
Wh1teAfr1can
Bright Orange is the way to go!! lol
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Wh1teAfr1can is offline        Reply With Quote
Old 04-02-2012, 01:23 PM   #16
NewR
I am running 12s, Edge 623mm main and 95mm tail with SK720 and the damn thing is so freaking smooth and rock solid that I am sick . I am a still a newbie btw and get 7:30 min, 80% discharge on 2x2650mah packs.
Gravity Fighter
NewR is offline        Reply With Quote
Old 05-03-2012, 10:30 PM   #17
TorqTube
Will Align servos work just as good as Torq servos?
Also what is a practical MAH when using 12s but two 6s lipo setup?
Old 05-03-2012, 10:31 PM   #18
Slyster
Originally Posted by TorqTube View Post
Will Align servos work just as good as Torq servos? Also what is a practical MAH when using 12s but two 6s lipo setup?
Align servos will be fine. I use a pair of Gens Ace 6s4000mah 25c packs... 7 minutes of flying.. they come down cool.
Pete Team Outrage.
Old 05-03-2012, 11:03 PM   #19
TorqTube
I believe HobbyPartz is the only store that carries them..send me a link if you can.
What do you think about using a HobbyWing ESC?
Old 05-03-2012, 11:07 PM   #20
Slyster
www.hobbypartz.com
Pete Team Outrage.
