Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 04-03-2012, 12:53 PM   #1
oldgrandpa
Default Wider Stance Landing Gear
What other make of wide stance heavy duty landing gear will fit the Pantera? I'm just learning & need all the help I can get.
oldgrandpa
oldgrandpa is offline        Reply With Quote
Old 04-03-2012, 01:16 PM   #2
Jermo
I guess you could get training gear or make your own. Search around.
Jerry Moore, AMA #878954, IRCHA #2988
Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL
Ok, you can fly...but can you HOVER??
KISS = Keep it simple stupid (to maximize fun and reduce costs!)
Jermo is offline        Reply With Quote
Old 04-03-2012, 03:31 PM   #3
forvols
Location: Resaca Ga - approx 45 miles South of Chattanooga, TN
JB sells 2 different styles of landing gear struts. The typical set is the narrow version I think, but he does have a wider stance, low profile set as well. Give JB a call and specifiy which style you're wanting.
If you're needing something to help prevent tip overs, you might want to consider making a set of training gear. The best I used was fashioned from a hoola hoop and used wood dowels as crossmembers to provide structure. The dowels were zip tied to the hoop, then the hoop was zip tied to the landing skids on the helicopter where the wood dowels intersected the helicopter skids.
something like this drawing...
And looks like this in real life application.....
Lifetime member of the Non-Sheeple Society
Awed by the young men/women serving in the US military
Ashamed of the men/women leading our nation
Saved to the uttermost!!!
forvols is offline        Reply With Quote
Old 04-03-2012, 06:54 PM   #4
jbeech
Actually, JB offers four different sets of landing gears struts!
AUD0033 is the lightweght 3D gear, which are standard
AUD0033-2 is the heavy duty wide landing gear struts.
AUD0033-3 is the new low profile gear molded in white
AUD0033-4 is the carbon fiber landing gear struts
Plus our training gear, which has the distinct advantage og disassembling very, very quickly with a twist lock at each leg. That, and the fiberglass rods can be shortened easily as you gain confidence. The nice thing about foberglass versus wood is each leg is the same while wooden dowls can flex differently due to the differing grain (and worse if the wood wasn't protected from the oil of the exhaust). Here's a link.
http://www.audacitymodels.com/Produc...3/Default.aspx
John Beech - GM (and janitor)
AMA # 47381
IRCHA #745
407-302-3361
jbeech is offline        Reply With Quote
