Old 07-08-2007, 05:16 PM   #1
Magenta
Default Tail Rotor Upgrade
Just replaced the stock tail rotor swash plate with the Align Metal Tail Pitch assembly. Now I get the full length of the tail rotor shaft without binding and was able to reduce the limit on the 401 from between 60-80 to between 80-100 (your guess is as good as mine on the numbers between)
Nice cheap upgrade that was well worth the money IMO
Magenta is offline        Reply With Quote
Old 07-08-2007, 06:52 PM   #2
thestunt23
You do know there is no swash on the tail. Are you talking about the slider? You should have had full travel on the stock one you took off. The metal ones have a longer shaft I believe, but I dont think you will use the whole thing. Congrats.
-Kevin-
thestunt23 is offline        Reply With Quote
