Go Back   HeliFreak > R/C Electronics Support > Airtronics Radios
Airtronics Radios Airtronics Radios Support
Old 04-06-2012, 01:18 AM   #1
fvdriver
Default Mixing problem
I am trying to mix elev-flap in an edge 540T, and I am not having any success. I have assigned a switch and it shows active when selected. But I go to the mixing, select elev-flap and increase or decrease the numbers and nothing happens.
Obviously I am missing something, but I have been over the procedure 4-5 times and I am at a loss as to what it could be. The set up is normal aero mode with 2-aile 1 flap. Should it be flaperon or 2 flaps?
fvdriver is offline        Reply With Quote
Old 04-07-2012, 12:34 AM   #2
cstoutr
Default Flaps
Do you have a channel assigned to the flaps? I'm understanding that you are using one servo for flaps. What channel is it assigned to? Try mixing the Ele. channel with your flap channel.
Team KBDD
Team Miniature Aircraft USA
MKS servos USA rep/ Helicommand rep
cstoutr is online now        Reply With Quote
Old 04-09-2012, 11:05 AM   #3
fvdriver
Yes I do have a channel assigned to the flaps. I was wondering if I had to have Flaperons active to get it to mix? I know this is mostly a heli forum...but heli guys are generally smarter than plankers.
Old 04-09-2012, 09:52 PM   #4
TMoore
Check out page 94 in the manual. There is a good description starting on that page.
TMoore is offline        Reply With Quote
