Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 05-09-2012, 05:17 PM   #41
johnbs8
yep thats exactly what happend to me. i thought i was the only one it ever happend to cuzz i never heard of anyone talking about it other then myself. yep toss it and slap on the new one.
Titan X50B : YS56sr GP Pipe, Tracx600 FBL, AR7200BX, Ds610 X4, DS650, Pushglo and compass 615mm FBL
Titan X50T : Ys56sr SAB-55 Pipe, Tracx600 FBL, AR7200BX, DS8717 X3, BLS251, Pushglo Radix V2 625mm FBL
johnbs8 is offline        Reply With Quote
Old 05-09-2012, 05:24 PM   #42
Bob O
Thanks john, I'll let you know if it takes care of the problem. Sounds like it will.
Sent from my phone
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 05-09-2012, 07:39 PM   #43
Bob O
The new belt solved the problem for now. Here's a short video that shows what it was doing and the sound it made. Here are also a couple of pics, one of the stock red belt and the other of the Thunder Tiger gold colored replacement belt.
You can see a slight difference in design between the belts if you look between the teeth. The gold belt has a little dimple there where the red belt doesn't.
ID:	315310   Click image for larger version
Old 05-09-2012, 11:50 PM   #44
WessCo
What part # for that belt? Mine makes the same noise.
WessCo is offline        Reply With Quote
Old 05-10-2012, 12:10 AM   #45
DethWshBkr
That's interesting - it looks like the belt is meshing too tightly on the tail gear, causing it to follow the teeth too long. Kind of like a bicycle or motorcycle sprocket that is cupped badly and the chain will not release.
Blade SR; Blade 450 3D; Blade MCP x; Thunder Tiger X50(TT)
Sig Somethin' Extra, Seagull MXS-R with 22cc gas engine!
DethWshBkr is offline        Reply With Quote
Old 05-10-2012, 06:57 AM   #46
Bob O
It's not so much the noise as it is the friction and vibes it must cause when it hangs up like that. I was hoping it would actually grab and stop the gear in the video but it never did. There were several occasions at the field in the very early stages of spool up when the belt would stick hard enough to actually stop the head. When it did this, it would result in a severe tail twitch. I can only imagine the problems this cause a person with their tail behavior.
This is the exact belt I ordered a while ago. Glad I had a spare on hand.
http://www3.towerhobbies.com/cgi-bin...?&I=LXAHBE&P=Z
I'm sure it's available at other places is you don't like Tower.
Yeah. I inspected the auto rotation pulley and it appeared fine, just like the belt. I really couldn't see where the teeth on the belt were worn to a different shape either.
Anyway, hopefully I can get in a few flights after work today.
Old 05-10-2012, 03:16 PM   #47
carlos
I have the same red belt on 2 of my machines but don't have the same noise.
please let us know what it was if you find the problem
If it won't hover, Don't bother !
carlos is offline        Reply With Quote
Old 05-10-2012, 10:23 PM   #48
Bob O
Two flights today..........wrung it out, tight 3D, big air, autos. Belt was super smooth and quiet.
Old 05-23-2012, 03:43 PM   #49
Bob O
More than a gallon of fuel later and the gold belt is doing just fine.......still super smooth and quiet.
Also, I'm currently running with a modded pin for the tail pulley.
http://www.helifreak.com/showthread....33#post3966133
I've also upgraded the tail boom supports to the Quick UK variety. They are longer and stiffer than the ones from my Velocity.
Old 06-03-2012, 06:53 AM   #50
WessCo
My tail is getting a little/lot twitchy. What ball spacing are you using on your rudder servo? Also, do you think the sticking belt could cause the twitching tail. I've turned the gain down to where the tail just does not feel locked in.
Old 06-06-2012, 08:00 AM   #51
Bob O
Sorry for the late reply. My ball spacing is 13mm on the tail servo/ Torq 9188HV on 2S LiPo. I'm running Edge tail blades and a gain of 78 in Gyro Sense at 2150 HS. This gets me a good hold but I get a slight oscillation in fast inverted forward flight.
The sticking belt had to have caused vibes, even at high speed. Although I never saw my tail fin vibrating or anything else like that. The new belt is still going strong with no problems at all.
Old 06-06-2012, 03:58 PM   #52
WessCo
We'll see. I've got a belt on the way. I was hoping that it'd be here today, but it didn't make it. Oh well. It'll be here tomorrow, just in time for me to go to work!
Old 06-07-2012, 06:03 PM   #53
WessCo
New belt, no sticking. Makes me wonder, if in a crash, the belt stretches on one side more than the other. Mine was fine pre-crash. Post crash is when it started sticking. Maybe thats a flaw of the red belts? Never had this to happen to a Raptor 50v2....yellowish belt.
Old 06-18-2012, 02:19 PM   #54
Bob O
Good to hear, Wess.
Sent from my phone
Old 06-18-2012, 06:44 PM   #55
WessCo
Also, maybe I flipped the belt around. If I ever have all of my helicopters up and running with no planes to work on, I'll put the red belt on and see if it still clicks by turning it iver. Found that tip on Raptor Techniques.
Old 06-18-2012, 06:46 PM   #56
WessCo
http://www.raptortechnique.com/faq.htm
Third tip down on that page.
