Old 04-07-2012, 04:52 PM   #1
rhodesengr
Default slow CCW rotation: how to trim?
I am getting a very slight CCW rotation. I thought I've read not to use TX trim to make adjustments so how can I stop this rotation? I don't see andything the the BeastX menus.
I am running the AR7200BX on a Gaui X2. Just doing hovering and some mild FF and I have to hold a little right rudder most of the time.
This is your brain on helicopters!
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550E FBL all with BD3SX
rhodesengr is online now        Reply With Quote
Old 04-07-2012, 07:46 PM   #2
latte
Have you done the tail-tuning part in the stickie here?
If you have, and still have drifting, then it is a sign of a vibration somewhere.
You are correct though, that you shouldnt use any trim or subtrim to try to fix this.
700E DFC - Ikon
700N FBL - Ikon
latte is offline        Reply With Quote
Old 04-07-2012, 09:31 PM   #3
rhodesengr
well I re-read the sticky and honestly my flying ability is not anywhere near the level required for step 6. My parameter D is on purple which I think was the original suggestion here. I can put it back to red "medium" and see if that helps. I might be able to do step 7 if I understood it better. Use a rate mode setting for the gain and change the rod length to compensate for tendency to rotate. I might be able to pull that off but I have never run in rate mode and when I have tried it the sim, I generay lose control.
maybe I'll just live with the slow drift.
Old 04-07-2012, 11:46 PM   #4
scott s
crank up your hh tail gain till the heli tail wobbles in a hover then back the gain down exactly 10% then start from there. It should be solid enough for a beginner
scott s is offline        Reply With Quote
Old 04-07-2012, 11:52 PM   #5
nwmtech
Set Parameter D back to Red. Increase your tail gain in about 5% increments in your radio until it goes away. Make sure
you're using the 3M tape as well.
Generally, a CCW rotation in a hover is a main tail gain way too low. Usually a CW drift is vibration. Those are just broad generalizations though
nwmtech is offline        Reply With Quote
Old 04-08-2012, 01:41 AM   #6
rhodesengr
will try tomorrow. I am using the 3M tape from the beginning. My first flight, I had put param D on purple (I think that was the set up suggestion here) and picked some nominal TX gain. The tail wagged so I lowered the gain and the wag went away. After a number of flights I started noticing the CCW drift. Not always but in parts of the flight. It was a little windy today so maybe that was taxing the heading hold.
Old 04-08-2012, 05:44 AM   #7
latte
It could also be a little too low headspeed for the tail-rotor to get enough authority.
But the BeastX is a really good tail-gyro, and should not allow any heli to drift as long as its in HH mode.
Blade balancing, mainshaft etc, it all has to be perfect.
700E DFC - Ikon
700N FBL - Ikon
Old 04-08-2012, 11:17 AM   #8
rhodesengr
I did just lower the pinion gear from 15T to 13T (this is on a gaui X2 with 3600kV motor) so the head speed was lower yesterday. However, I was seeing the CCW drift the day before with the 15T gear. I am hopeful that increasing the gain will fix it. I'll know in a bit.
Old 04-08-2012, 03:27 PM   #9
rhodesengr
just to update: The slow CCW rotation is gone. I put param D to red and upped my TX setting from 63% to 70%. The rotation seems to be gone. I'll try upping the gain to see where wagging sets in as recommended and then bacl down.
Thanks for everyone's input.
Old 04-08-2012, 05:36 PM   #10
latte
Glad you got it worked out! =)
700E DFC - Ikon
700N FBL - Ikon
Old 04-08-2012, 06:22 PM   #11
nwmtech
