Old 04-07-2012, 04:57 PM   #1
tommeke
Default dfc head
can you use the stock mainshaft on a dfc head, so that the head isn't lowered (boomstrikes), in my case a trex 500 ?
tommeke is offline        Reply With Quote
Old 04-07-2012, 05:09 PM   #2
Larry227
Check this thread http://helifreak.com/showthread.php?t=392370
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote
Old 04-07-2012, 05:10 PM   #3
tommeke
thanks mate!
Old 04-07-2012, 05:25 PM   #4
tommeke
can't realy find if it was mentioned there ?
Old 04-07-2012, 08:15 PM   #5
Larry227
I don't have that head but my guess is it wouldn't work with the longer shaft because the tubes going from the grips to the swash would be too short. If you don't want to use the shorter shaft maybe consider the Tracx FBL head. I'm pretty sure you can use the standard FBL shaft with that. There's a long thread on that head in the 500 forum also.
#nodroneshere - 104
Old 04-07-2012, 09:28 PM   #6
americas911
I have seen a couple pics where they used the stock shaft and bought some lunsford titanium turnbuckles instead of the short ones that come with the DFC head. Dont remember where I saw it though.
americas911 is offline        Reply With Quote
Old 04-08-2012, 05:33 AM   #7
Deet
There are no reports of boom strikes on a 500 DFC
The one video was a 700 with questionable blade
I have done everything possible to make contact between the blades and a boom on the 500 and it simply can't be done
The whole point of the DFC is to lower the head, if you don't want that, use another FBL head
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote
Old 04-08-2012, 11:11 AM   #8
sarmeneau
no you cant your links would be way to long. and +1 deet ive tried also and cant get it close.
Trex 500 ESP DFC FBL
BLADE 130X
GOBLIN 630 CC 120HV, Scorp 4225 610Kv, Outrage servos, Skookum SK720BE GPS combo
sarmeneau is offline        Reply With Quote
