Old 04-09-2012, 07:35 AM   #1
jabu32
Default Tarot ZYX-S or ZYX?? whats the difference?
im looking into converting to FBL. i think im going to purchase the tarot fbl unit (are the copterx better?) and saw that there are two models. the -S is the newer on i guess but i dont know what the difference is. Anyone? thanks
Hello My Name Is Joe
Blade mCP X BL - HP06V2 / Blade mCP X BL - Spin 16.3K / Blade 400 - DS760, 450MX / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX
jabu32 is offline        Reply With Quote
Old 04-09-2012, 10:25 AM   #2
atlny
I believe one uses satellite and the other use a full receiver
Blade CX2, Blade 400, T-REX 500E PRO FBL AR7200BX, Blade 450 FBL, Blade mCP X V2, T-600 PRO DFC AR7200BX
atlny is offline        Reply With Quote
Old 04-09-2012, 02:33 PM   #3
jabu32
any benefit getting the -s version other then that?
Old 04-09-2012, 08:33 PM   #4
atlny
a cleaner setup less wire
Old 04-10-2012, 07:56 AM   #5
jabu32
is it enough to just use a satellite? can you use a full size rx still?
Old 04-10-2012, 10:33 AM   #6
atlny
The satellite should be fine as long as you mount them correctly
If u want to use a full RX just get the zyx not the -s
I like the -s because it would be less wires But it's too late for me
What's sIze is your heli also if u are using a DX6i you might have do the full RX setup
If it's anything like the 3gx the gain is map throught channel 7
Old 04-10-2012, 11:14 AM   #7
jabu32
well that answers that. i have a dx6i and going to use it on a 400.
Old 04-10-2012, 12:40 PM   #8
atlny
Well, you are ahead. I found this out after I have bought the satellite and spend hours trying to get it to work
Old 04-11-2012, 12:23 AM   #9
Harbormaster
I have both JR and Spektrum satellites working with a DX6i with no trouble at all. Plug and Play!
VBar T-Rex 250 & 450 * Tricked-out Blade 400 with CopterX FBL * mCP X
Harbormaster is offline        Reply With Quote
Old 04-11-2012, 05:39 AM   #10
atlny
I guess it's not like the 3gx then
Old 04-11-2012, 06:54 AM   #11
jabu32
are you using the satellite along with the full receiver?
Old 05-05-2012, 02:07 AM   #12
ausi1972
Default Zyx-S with satellite & for Quads
If you want to use the satellite with the Zyx-S then you need to bind your radio (Dx6i works fine) with a full Rx with the satellite plugged into it, then remove the satellite from the full Rx and plug it into the Zyx-S with the special cable that you have to buy separately.
Also the Zyx-S can control planes and quadcopters as well, so they are well worth the extra couple of bucks.
ausi1972 is offline        Reply With Quote
Old 05-05-2012, 12:29 PM   #13
averhamdave
Sory but I'm struggling to undersatnd!
The ZYX is a FBL gyro system, OK?
The ZYX-S is a FBL system with built in RX? - Like a V Bar?
I was going to ask the same question as the OP. I have a new ZYX on my 450 PRO and just can't praise it enough. It has no Sattelite socket so will be a ZYX, right?
If I bought a ZYX-S, I wouldn't need a receiver as well?
Thanks, Dave
averhamdave is offline        Reply With Quote
Old 05-06-2012, 11:28 PM   #14
Vinger
The -S version can accommodate a satellite RX via a special lead that plugs into one of the normal RX leads on the unit. It does NOT have any RX built in. You can still use a standard RX with it as well. Supports aircraft and quad copters.
or normal RX
Support aircraft and quads
The standard version can only be connected to an external RX via the fly leads. Only supports helicopters.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC
Hyperion 1420, Mega Power Gemini Chargers! JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 07-06-2012, 12:54 PM   #15
Jazzjohn
Vinger,
Which software are your screenshots from?
I downloaded the latest stable version from http://fbl.net.nz but it doesn't have the plank and quad stuff in it.
Thanks.
:::::No Flybar Zone ::::
V120D02S x2 : Genius CP v1 x3 : Genius CP v2 : Master CP : Ladybird : Mini Protos
Jazzjohn is offline        Reply With Quote
Old 07-06-2012, 01:07 PM   #16
drdispatch
Looks interesting - are these gyros performing well?
Sorry to hijack - I was literally just thinking about getting one of these units for a junk 450.
Synergy N5c YS56, CGY750
Gaui X5 Vbar
MSH Protos Vbar
Blade 130X
drdispatch is offline        Reply With Quote
Old 07-08-2012, 02:07 PM   #17
1275mini
just ordered a xyz -s and satellite lead for my trex 500/dx18 where can i download the pc software as above ?
Barry
1275mini is online now        Reply With Quote
Old 07-08-2012, 11:21 PM   #18
Dr. M
All you would ever want to know about these systems is referenced in the first post of this thread:
http://www.helifreak.com/showthread.php?t=414428
Sorry, I know there's a lot of reading to do, but I can't think of any other way to convey this huge mass of information.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is offline        Reply With Quote
Old 07-09-2012, 05:36 AM   #19
petedee
The ZYX-S can use either a full radio or just a satellite and can also do quads as well.
DJI Naza 330, 450 & 550 hexa, TBS Discovery (Naza-M/5.8Ghz vid link/ET telemetry), KK2 micro hexa and micro quad, Nano Ladybird/Spektrum Hybrid, Nano MQX hybrid.
300X, Trex 450 Pro DFC, mCP X's, mSR X, nano CP X
DX18, 14SG
petedee is offline        Reply With Quote
Old 07-09-2012, 05:40 AM   #20
1275mini
That what i like to hear !!!
Barry
