| Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum |
#41 |
Now the Vbar has put out a new sensor with the same chips as the cgy, the last unique selling point of "vibe-resistance" is gone. I hope futaba realize the seriousness of the situation, theres no stopping for customers going to Vbars other that the cgy sells cheaper.
Also the Cgy asks you to have a sbus receiver, already selling at premium. Hurry up futaba, I buy everything futaba long time, but this time, I'm scraching my head too. |
#42 | |
Greg Lynx Team Pilot Heli: TDR; Logo 600,500; Trex700E,500,450,250 Flight video: http://www.youtube.com/watch?v=GUkswcoyGEk&feature=plcp |
#43 |
Is it? Had a multigov before and I can say that's a good nitro governer..
Vbar has nitro governer too, don;t know if its good thou.. And compare to the sales ratio of nitro vs electric. Drives the good nitro governer argument less valid too for making more sales of cgy and the accompyning sbus recievers. And i love nitros. Common Futaba~ This is supposed to be the flagship product that captures the flybarless crowd. with the new sbus and all other flashy stuff |
#44 |
If you are having big drift issues i would suggest trying my trim setup.
You will need to reset the swash menu to so though. be sure to copy your expert and std settings down for swash , ail, elev before doing so though. You can renter all of them after. You will also need to be sure your links are all identical. use a micrometer with ball link adapters. The more precise the links the less chance for drift. i also suggest using a bubble swash leveler. If you can get your heli level..then the bubble swash level will work excellent and may result in no drift on the first flight! (assuming weight balance is good) i personally think the standard trim method was designed with good intention but is very flawed. I much rather my trim be tied to my cgy750 instead to my radio. When The cgy750 memorizes the neutral point the assumption becomes the radio input will be always the same..my experience with the 8fg has shown me this isn't possible since it can require frequent calibration depending on condition. I would assume that recalibrations have potential to affect the previously set trim flight. this is why i think many have mixed results with trim flights and why my method works for me. Sent from my SCH-I510 using Tapatalk 2
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025 Gaui X6 vbar silver 5.3 YGE120HV 700mx ElektroRC.com field rep (YGE, MSH, LAHeli) |
#45 |
Hi Joe,
By "condition" do you mean flight condition or something more environmental? Have you seen the 8FG calibration drift over time/temp etc? Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail Futaba 8FG 2.4GHz |
#46 |
I have seen and read of 8fg calibration drifting over time. Futaba added the calibration menu last year for this reason. It is not uncommon at all from what I have seen. This is why i think results vary. i had 2 8fgs...the first would drift every couple months the 2nd has been good for over a year. it all depends on age condition etc.
#47 | |
I am experiencing similar problems (wobble & drift) to others on the thread using the 750 v1.2. I read your post (above) stating you went back v1.1. How did you accomplish this? Thank you in advance for your assistance. Stuart |
#48 |
Anyone?
#49 |
You need the futaba USB interface ( CUI2 ) . This will allow you to d/l the 1.1 software and install/downgrade your firmware.
#50 |
Hi, I had a lot of wobble on my new velocity and i'm using a cgy for the first time. I have changed the i and d gains to whats been suggested here and its now flying very well. What I wanted to ask is with the i and d gains, is it suggested to change them to 60 and 40 on both ail and elv? I now have a lot of bounch back on the elv so i'm wondering if I should have just changed the ail side to stop the wobble.
Also what is and what does the i and d gain do? and why is it such a big change to make on the d gain from 200 to 40? |
#51 |
I only changed the aileron and that did the trick for me.
AMA Leader Member Team Futaba Raptor 90SE/YS91ST - T550E FB - T550E FBL w/CGY-750 |
#52 |
According to Dr.Bens tropic on RR:
AIL woobling can/might solved by lowering the Ail. D.gain. Ele Bounce can/might be solved by increasing the ELE Stop Delay. http://rc.runryder.com/helicopter/t672354p1/ See the first tropic
ChopperKnud, Team Heliwholesaler - Team Miniature Aircraft ThePitchbrothers.com Last edited by Knud Pedersen DENMARK; 06-04-2012 at 03:16 PM.. Reason: typo |
#53 |
Any idea when Futaba is going to fix the firmware? Is anyone beta testing the next update?
#54 |
I guess I am thick as a brick because I do not know what you think needs to be "fixed". Beyond that I have no clue when the next update may come out.
#55 |
For exmaple the tail going left on stationary flips
Dr.Ben confirmed with me personally that its an known issue. And you don't know about it? |
#56 |
My 550 does not do that, so no, I am not aware of it.
#57 |
I don't think I've seen that either, but given my experiences with StpBoost causing a tail shimmy during such flips, there does appear to be some unwanted tail interactions here.
Steve
#58 |
Yeah it is an issue. On my Trex 550 I kept on changing tail settings, until I found out that in fact is appears to be an "aileron" thing. It is especially noticeable with (violent) rainbows or tic-tocs. You see the head button makes this sudden twist to the left, and thus it appears that the tail drifts. I even compensate now with my thumbs for this movement! When you crank up the aileron gain, it gets worse. I haven't changed D-gain or I-gain yet, some say that helps. Otherwise the heli flies perfect, locked in.
Cheers, Jan |
#59 |
I love my CGY750's but its taken Futaba much too long to fix the problems in v1.2. I have to admit that my vbar and BeastX have seen significant improvements since CGY750 v1.1 and v1.2 firmwares were released. The edge that i felt the CGY750 had on the vbar has really shrunk now...even more so with the release of the silver line. I expected a quick turn around since the problems in v1.2 were quite widely seen...but instead its starting to look like Futaba forgot. I've been a big supporter of the CGY750 since day 1 but its been a year and it still takes hours of setup to get the heli to not drift.....
#60 | |
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar Kasama Srimok ECO CGY 750 Mini Prôtos CGY 750 |
