Old 04-13-2012, 02:46 PM   #41
Luisito
Awesome!!! Showing off the pictures here at the Austin Fun Fly.
Any chance of taking close ups with the canopy off?
Luis
Logo 700 XXtreme, SAB Goblin 700, SAB 770: Logo 600SE Carbon Fiber Frame 12S: Pyro 700-45, Kontronik 120 Heli Jive, 11T Pinion, Full Size V-Bar 5.3, 693/105 Blades Align 550E: Pyro 600-12, CC100, 17T Pinion, Full Size V-Bar 5.3, 553/86 Blades
Luisito is offline        Reply With Quote
Old 04-13-2012, 02:47 PM   #42
drdispatch
Very nice stuff!
Synergy N5c YS56, CGY750
Gaui X5 Vbar
MSH Protos Vbar
Blade 130X
drdispatch is offline        Reply With Quote
Old 04-13-2012, 02:49 PM   #43
marcosp
New pics on ReadyHeli FB. 700 no canopy. It's a Scorp V5.
Marcos
Banshee #27, 2x TDR, Diabolo, JR Sylphide E12, Voodoo 600, Voodoo 400, Avant Aurora 90N, Rave 450, Gaui X2
marcosp is offline        Reply With Quote
Old 04-13-2012, 02:50 PM   #44
Mathias
Originally Posted by MrMel View Post
There is NO ETA's at this time, this is only pictures what to come, NO DATES...
I'm happy they do not, DFC may be cool looking but good design it's not.
Is that basically because with the DFC design the pitch link needs to handle both the torsion forces acting on the rotor head, in addition to transferring the pitch inputs to the main grips simultaneously? With the separate pitch link/swash driver design the forces are more equally distributed, as they've got separate functions.
However, the DFC design does lower the CG a bit more than the separate pitch link/swash driver design, even though the new Mikado heads have a design which integrates both the main rotor hub and swash driver into one single unit.
Edit: Wow, thread progressing fast!
Mathias
Mikado Logo 700 Xxtreme | Blade 130 X | JR XG8 & Spektrum DX8
Mathias is offline        Reply With Quote
Old 04-13-2012, 02:54 PM   #45
djamgils
problem with DFC is when spindle teeters in the dampers.
The best is still with a regular swash driver. But that is an entirely different discussion
JR Nex E8, and E12 Hiroki Ito Edition
djamgils is online now        Reply With Quote
Old 04-13-2012, 02:56 PM   #46
Blink 182
Most likely a Jive 120 with a different heatsink.
Originally Posted by Konrad78 View Post
What ESC is that in the 700?
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Blink 182 is offline        Reply With Quote
Old 04-13-2012, 02:57 PM   #47
MrMel
V-BAR Guru
Its a Scorpion in that 700, more pictures without canopy on RH facebook page.
MrMel is online now        Reply With Quote
Old 04-13-2012, 02:58 PM   #48
Mathias
Originally Posted by Blink 182 View Post
Logo 700 head and main shaft are scaled down so not the same size.
Well, looking at the pictures the main blade grips are using spacers to fit the 700'ish mm blades. Xxtreme grips much...?
BTW: I would imagine that the DFC heads would work better on a small helicopter (250, 450), as the forces acting on the rotor disk are much smaller.
Mathias
Old 04-13-2012, 03:02 PM   #49
Blink 182
I saw another Logo 700 with a Scorpion 130A ESC but it has Thunder Power packs and Kyle doesnt use those.
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Old 04-13-2012, 03:05 PM   #50
Blink 182
Grips are smaller also.
Main reason I believe the Logo XX head was not used on the 700 is weight, mainshaft, spindle + 800 size headblock and grips are over kill. Going to a scaled down 800 head saves a great ammount of weight.
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Old 04-13-2012, 03:07 PM   #51
gravydrive
The XXtreme uses spacers on its grips also. Reason is, they needed to enlarge the grip openings to fit the large thrust bearings they're using. I doubt that the 700 grips are the same as the XX.
gravydrive is offline        Reply With Quote
Old 04-13-2012, 03:15 PM   #52
npap
Sorry but the 700 with red canopy it's a jive and the one with yelow canopy it's a scorpion 130A...
I really prefer the yellow one
Eat.Sleep.3D....add to cart
npap is offline        Reply With Quote
Old 04-13-2012, 03:20 PM   #53
Konrad78
Fit without any modification needed (well, you probably need the mainshaft) but that's probably it, i.e. same pinion as far as I know.
Why do you need a different mainshaft?
TRCHK
Konrad78 is offline        Reply With Quote
Old 04-13-2012, 03:24 PM   #54
Nitros83
as i understood because there is the 3rd bearing for the main shaft too
Nitros83 is offline        Reply With Quote
Old 04-13-2012, 04:01 PM   #55
Justin Stuart
What's the benefit of the new Vbar over the old?
Avant RC
Scorpion Power Systems
ThunderPower RC
Kontronik Drives
Justin Stuart is offline        Reply With Quote
Old 04-13-2012, 04:13 PM   #56
MrMel
V-BAR Guru
Even less sensitive to vibes as far as I know.
Old 04-13-2012, 04:17 PM   #57
Nitros83
is it more oriented for nitro and gasser machine then?
Old 04-13-2012, 04:23 PM   #58
Konrad78
Cant you just put tighten the main shaft collar a bit higher?
TRCHK
Old 04-13-2012, 04:48 PM   #59
Mathias
http://www.youtube.com/watch?v=r9XAPvYUXq4
Obviously, this issue can easily be avoided making a good head block initially in the design process...
Mathias
Old 04-13-2012, 06:27 PM   #60
rappyfly
Great to see th new logo 700 and additions on the logo 600. Finally logo 600 has a third bearing block and thicker main gear, and hope it wil solve the gear problem.
I cut down my motor shaft to clear off the batteries, is long motor shaft needed to use the new parts? Since the sx parts are addition to the current 600, hope these will be available soon.
rappyfly is offline        Reply With Quote
