| Walkera Helicopters Walkera Helicopter Support |
I've done all I can do with the 4-channel helis, thought I'd try the 6-channel thing. I have a WK-2603 TX that I'm trying to learn. I have just about figured out the functions of all switches except one - the "flight mode" toggle. The marking on the unit shows "stunt mode" to the left and "normal" to the right. The problem is that the toggle actuates forward and backward.
Help! Thanks. Phil
My mission is to comfort the afflicted and afflict the comfortable. |
Forward is normal mode (away from you if you're holding the transmitter), with a slower headspeed for softer flying. Stunt mode initiates when you flip the switch back toward you, and has a higher headspeed and a full pitch curve for inverted flight and sport flying.
Is this what you're asking?
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX // // Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) // // EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX // // WK2801 // Spektrum DX4e // |
Yessir, and I do appreciate it!
bevery carefull with that stunt switch heli will spin to 100%power in a second so becarefull it hapend to me and all moest took my head off!
I usually switch to idle up in the air, although with the 2603, I would get a jump in altitude when switching to idle up, then a drop when switching to normal, so be careful of this. With my 2801 I was able to program my pitch curves to handle the in-flight switching of modes without losing or gaining any altitude.
