Old 04-16-2012, 06:13 AM   #1
faceman425
Default best mod for stock canopy pins
What have you guys done (other than not crashing) to the canopy pins to get them to hold up better. I have carefully put shrink wrap around mine and held up pretty good. Hate to do it to the new frame I have as you have to be super careful not to heat too much or it disfigures the frame. Just wanted some other options. Thanks
Trex 700E FBL Vbar Blue, CY Rave ENV Nitro Vbar Silver, Trex 250 Pro DFC (stock for now), Blade 130X-1 stock, Blade 130X-2 Blingged, JR 9503X
faceman425 is offline        Reply With Quote
Old 04-16-2012, 06:17 AM   #2
catpainkev
Astroid Designs did do a cf brace for the pins which was apparently very good...I have been trying to get some, unfortunately without success...that aside I haven't heard of any other methods..but I'm all ears as I'm about to rebuild mine into a new frame right this minute
catpainkev is offline        Reply With Quote
Old 04-16-2012, 08:26 AM   #3
Glass Monkey
i just cut em off, drill a little hole at the base and insert cf rod with a little ca glue, works like a charm.
Blade MSR, Blade MCPX BL(hp05s, xp7a, sr120 tail, all MH head), EXI 450CF, TREX 450 pro(CC Ice 50, Scorpion -8, BeastX, KBDD TR, Trueblood greens), TREX 500 (BeastX, Align DFC head, KBDD TR)
Glass Monkey is offline        Reply With Quote
Old 04-16-2012, 09:04 AM   #4
ebeing
toothpicks work well, they adhere to the plastic very well.
130x | mCPX | mSRX | DX7S | mCPX BL
ebeing is offline        Reply With Quote
Old 04-16-2012, 09:21 AM   #5
UKHeliBob
The front ones are easy. CA a length of 1mm CF rod or music wire onto the frame parallel with the pins taking it right across above or below the 3 in 1 mounting posts. Then wrap thread around the joints with the canopy pins and add more CA.
The back ones are more complicated. You can do something similar with bent music wire attached to the frame behind the main shaft but you have to be careful not to interfere with anything else.
UKHeliBob is offline        Reply With Quote
Old 04-16-2012, 09:38 AM   #6
Naito
I reinforced my front pins with a single 1mm CF rod CAed to the pins passing through the motor area. Actually it might be 2mm, I had more space when I switched to BL and had the room to spare. The rear ones are more complicated, but did a similar thing, cut up a piece of CF rod and used thick CA where it connects to the frame and made sure the two pieces were just long enough to touch the frame and sit behind where the canopy notches in. Then shrink wrapped all 4 canopy pin + cf rod combos.
I've managed to crash these hard enough that the tip nubs where the canopy notches in breaks off but the rest of the pin stays connected to the frame. I'm pretty happy with this mod, it's heavier than just replacing the rods entirely with CF but it's plenty sturdy.
Naito is offline        Reply With Quote
Old 04-16-2012, 12:19 PM   #7
Brett74
Can anyone post a pic of this mod ?
Kasama Faifa 4525 520 Ultimate Ice 2 120Hv VBar (gov)
Goblin 700 4530 540 LE Ice 2 160HV VBar (gov)
Brushless MCPX
Brett74 is offline        Reply With Quote
Old 04-16-2012, 01:52 PM   #8
UKHeliBob
Something like this, but neater !
Name:	mcpx frame 1.jpg
Old 04-16-2012, 04:53 PM   #9
litehawkdown
Here is a shot of mine. Also shows how I tie my links together. I used a 99 cent Plank pushrod to make mine. I bend mine around the front of the bearing. If you take your time it looks nice and neat. I am modding my original frame. Just waiting on some CF rod. I might post some pic's of the process in one of the stickies so it won't get lost. Wish I could do a weight comparison of before and after. But I don't have a intact stock frame to compare to. This mod is like $ in the bank.
litehawkdown is offline        Reply With Quote
Old 04-17-2012, 11:55 AM   #10
Naito
Only have my phone camera on me, so excuse the poor picture quality.
ID:	308911   Click image for larger version
Old 04-17-2012, 11:58 AM   #11
newhelliguy
Do away with pins
http://www.helifreak.com/showthread.php?t=395470
20 something various Helis, Msr through 90's.
How many helis do you need? Just one more.
Sk720 equipped
newhelliguy is offline        Reply With Quote
