Old 07-15-2007, 05:15 AM   #1
Magnumeng
Default Night Rig Glitching
Flew my TREX 450 Night rig tonight and was getting some glitching... I did not get any glitching before I switched it over. Here is what I am using.
Radio - 9Z WC2
Reciever - R146iP
Servos - HS 65 MG
Gyro - 401 w/9650
Stock Motor and ESC
Align night set up.
9v battery mounted directly below the reciever. Is this my down fall?
Chad
TDR, Kosmik Cool 200, Pyro 750-56, Futaba HV, Futaba CGY750
Team KBDD
Magnumeng is offline        Reply With Quote
Old 07-15-2007, 05:40 AM   #2
R-4-L
I wonder if using a 2.4ghz radio system also eliminates such glitch sources. like lighting, motor, bad connections. sorry don't mean to hijack your post. but it could be a bad connection.
R-4-L is offline        Reply With Quote
Old 07-15-2007, 05:49 AM   #3
Magnumeng
I will look over my connections... I am using 72mhz system...
Chad
Team KBDD
Old 07-15-2007, 02:46 PM   #4
Ivan
What kind of glow wire drivers are you using. If they are the cheaper kinds you find for $5 or less, they throw all kinds of trash over the radio waves. I had a brand new set of 710 night blades that only had a lifespan of about 15 seconds because of that very reason. It was bad enough that it even defeated the PCM signal.
After I got a driver from a quality source, the problems were gone.
I came, I saw, I hovered
Ivan is offline        Reply With Quote
Old 07-15-2007, 03:11 PM   #5
Magnumeng
My Glow wire is the from ALIGN... total the system is about 30 bucks
Chad
Team KBDD
Old 07-15-2007, 03:58 PM   #6
Ivan
this is the one I got that works well:
Glow wire
I can't find any stuff on the align glow drivers, so I can't tell if they look like the ones I had before. Does the heli glitch when the drivers are turned off?
Old 07-15-2007, 05:04 PM   #7
Magnumeng
I flew it all day with the driver off to get use to the difference in weight with no noticable glitching.
After my first flight I noticed that the cyclic was glitching. I am going out today with out the night gear on to see if it does it again.
Chad
Team KBDD
