Go Back   HeliFreak > R/C Helicopter Support > Turbine Helicopters
Turbine Helicopters Turbine R/C Helicopters
Old 04-16-2012, 06:13 PM   #1
ppridday
Default Check this out...
Not sure if you guys have seen these before or not. Looks like it could be a heli saver.... At least part of it....
http://www.troybuiltmodels.com/items/RESFLAMEOUT.html
Paul
I love the smell of kero in the morning....
ppridday is online now        Reply With Quote
Old 04-17-2012, 01:16 PM   #2
5.9Cummins
Interesting... could save a plane or heli! But a fire extinguisher is better! Did you see that video, the fire extinguisher was right under the table!
Raptor 30 V2 || Futaba 10C || GY401 || OS 37||
5.9Cummins is offline        Reply With Quote
Old 04-17-2012, 02:41 PM   #3
ppridday
Definitely not a replacement for a fire extinguisher, but if you can get your smoking turbine on the ground and discharge that while your buddy is running to it with the extinguisher it could save some serious $ in damages...
Paul
Old 04-18-2012, 05:58 AM   #4
lperagallo
Yeah, there was a fire extinguisher under the table, but based on the hose attached it may have been water, not CO2 or powder, not that I'd want powder anywhere around the turbine.
That's why the AMA requires a CO2 fire extinguisher available whenever you fire up a turbine.
Lou
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
www.circlecityhelis.com
lperagallo is offline        Reply With Quote
Old 04-18-2012, 01:06 PM   #5
cbergen
Actually it's a B/C rated, not specifically stating CO2.
16. A “B/C”-rated or equivalent fire extinguisher shall be present for all engine starts. Water based fire
fighting equipment shall be present on the field.
http://www.modelaircraft.org/files/510-a.pdf
As turbine owners, we DO recommend CO2 fire extinguishers.
I do like the idea of that onboard system, but it's probably better utilized in scale fuselaged models. Not sure how much good it would do in our pod and booms. Would be neat to test it out.
Chris D. Bergen
Bergen R/C Helicopters
cbergen is offline        Reply With Quote
Old 04-18-2012, 07:58 PM   #6
desertstalker
The others will put out your turbine, permanently. I hate to see the mess a power extinguisher would make of the inside of a turbine, even water would be bad.
-DX8
Old 04-18-2012, 08:47 PM   #7
cbergen
I have pics if you would like to see...
Chris D. Bergen
Old 04-19-2012, 12:47 AM   #8
desertstalker
Better mark them, wouldn't want to scare the kids...
-DX8
Old 04-19-2012, 02:27 AM   #9
Skiddz
Actually Chris, I would like to see.
-Kevin
Skiddz is online now        Reply With Quote
Old 04-19-2012, 12:00 PM   #10
5.9Cummins
+1... I am also curious to see some pictures!
Old 04-19-2012, 02:24 PM   #11
ppridday
It's not Bill's is it?
Paul
Old 04-21-2012, 08:50 PM   #12
cbergen
No. Bill's Fire Extinguisher was empty...
Chris D. Bergen
Old 04-23-2012, 07:18 PM   #13
cbergen
Here is a Wren 54 case that has been hit with a Dry Powder Fire Extinguisher. The yellow stuff is hard as a rock....
I chipped the large pieces out, then took a scotchbrite pad to the rest.
Name:	dry powder in turbine.jpg
Chris D. Bergen
