| Blade 450X Blade 450X Helicopters Information and Help |
#21 |
#22 |
Get them changed or risk crashing because of the nylon geared servos's....
It would be awful to watch your bird fall from a manky servo that you knew you should have swapped out, especially if you're fbl'd, your servos carry more load..... ![]() |
#23 |
Wait until they strip on your next hard landing or crash to swap them out. They work fine so long as your blades aren't hitting anything but air.
Bought a five-pack of stock servo gears myself. I'd rather have a gear strip than a pitch link bend, swash ball snap off, or grip link snap. It's all about deciding where you want your point of failure... and as 3/4 of the servos on this heli can be rebuilt in-place (stupid elevator), I'd rather take the five minutes it takes to replace the gears. And keeping all of the NON-stripped ones, you usually can save between half and 3/4 of them for a future rebuild. Really, aside from the apparent designed-to-fail gears, they seem like perfectly good parts. Now to find a micro CNC machine...
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X Spektrum DX8, DX6i |
#24 | |
I say keep them for now and swap them out when one strips. the DS76 is a perfectly fine servo. It's not great, and it strips easy in this big heli. But it's pretty smooth and cheap. And the DS76T tail servo on our 450x is one of the fastest tail servos you can get! If/when I decide to move to a metal gear servo, I'll probably go with the H3000.
Blade 450X w/BeastX - Align T-Rex 250 FBL w/ Tarot ZYX-S - Blade 130x - Blade mCP X BL - Blade Nano CP X Brushless Spektrum DX8 AMA #1010394 |
#25 | |
2 X Blade mCP X v2 ♦ night fly Blade mQX ♦ LadyMQX hybrid ♦ Blade 450X w/telemetry and Loc8tor ♦ Blade Nano CP X ♦ Compass Warp 360 w/AR7200BX, (2nd) Koby 40, DS92A+, DS95i, telemetry and Loc8tor ♦ Spektrum DX8/DX6i |
#26 |
ahh I don't usually look at the dates. No idea how I ended up in that thread if it's that old. I usually only read the first page.
#27 |
Digital servos develop full torque at neutral, analog servos cannot....because of their slower update rate.....
Digital servos can hold their position better, because of the higher update rate....that analog servos can. Because of the higher update rate, digital servos have a tighter deadband than analog servos. FWIW |
#28 |
I ended up switching the servos right away, and am glad I did. I have two 450x's. One is stock, the other has metal gear servos. The difference is major. I will be selling the stock 450 very soon, it was a spare for when I had crashes. I don't crash as often now, so it doesn't get used anymore. I changed the tail servo to a Saxon and am very happy with it, the stock one lasted about a year. www.ampdraw is an excellent company to deal with and their prices are almost always cheaper than other sites. I highly recommend them. I also use www.hobbyking, www.readyheli and www.amainhobbies a lot. www.amainhobbies and www.hobbyking were great on their warranty on two situations that they could have been hard line and not warranted the items. Hobby King warrentied a 6S 5000mah battery, which is tricky as batteries generally are not warren tied. The balance plugs were sparking. www.amainhobbies warranted flybar rods on my trex 600 because they make 2 sizes and I ordered the wrong size. In both cases these companies could have said no.
As far as servos on the Blade 450x, the one I kept stock has had to have the servos changed many times. On the one with the metal Spektrum H3000's I've never had to replace one servo. I've got a lot of flights on these and know exactly how the servos last. Hi EEngineer, hope all is well. Guy
Whiplash 700E // Trex 700E // Trex 600E // Trex 550E V2 // Blade 500X // (2) Blade 450X's // Blade 300X // Trex 250 DFC // Blade 130X // Blade Mcpx // Blade SR120 // Blade CX2 // Blade Msrx // Blade Nano // HeliMax 1SQ // Walkera 400 // 2- DX8's |
