| YGE YGE ESC Support and Discussion |
hi
what PWM frequency does everyone use for their kontronik Pyro Motor? YGE esc only goes up to 16khz but manufacturer recommends 32khz for the pyro motors what motor timing works best? |
heres the formula ...PWM calc (KV x V x poles) / 20 then round down to nearest although
14 seems to work well with my pyro 600-12 |
you sure that fromula works
if thats the case the scorpion 1400 would run at 14khz but scorpion recommends 8kz most 3s 450 motors would be around 5khz |
From my experience, formula is just also for orientation and reference. All thing you must do the tuning by yourself and figure out the best number which you achieve.
-Logo 600, Full size Blueline 5.3 + BLS 251, Cyclic Fu BLS 252 powered by Life 2s 6.6 V, HK III 4035 - 500 kv + Vbar Gov, YGE 120 HV To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail Futaba 8FG 2.4GHz |
