| Multi Rotor Helicopters Multi Rotor Helicopters Info and Support - Tandem, Quadcopters, Tricopters, Octocopters, and Hexacopters |
So I'm helping a friend setup a NAZA using 30a hobby wing ESC's. I've done some reading and the NAZA manual states to use a BEC and remove the red ESC wire for all aerial photography and over 650 size mutlirotors. Well here is the quote from the manual
"We recommend the use of external switching type BEC of 5A or higher for all AP work and larger than 650 size multi-rotor, and cut the red wire of ESCs with built-in BEC." This is a 450 sized quad with 2a/5v built in BEC's. I could be reading this incorrectly. Should I leave the red power wires or remove them? Any input is appreciated. Thanks guys.
_______________________________________ T-Rex600ESP, Quad copter DJI/FPV-VIC frame/NAZA, Hexacopter550 NAZA 4s FPV |
Remove them all and use the inbuilt BEC of the Naza. That is how mine is set up and works great.
DJI Naza 330, 450 & 550 hexa, TBS Discovery (Naza-M/5.8Ghz vid link/ET telemetry), KK2 micro hexa and micro quad, Nano Ladybird/Spektrum Hybrid, Nano MQX hybrid. 300X, Trex 450 Pro DFC, mCP X's, mSR X, nano CP X DX18, 14SG To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Thanks petedee. I will be trying that out. I didn't even stop and realize the NAZA has one built in. Sweetness. After I calibrate each throttle endpoint individually, and set the esc settings up, we are up and going. I love this site!
Yes it is about that easy, make sure you set a switch up for the two modes, I am using the gear switch but some people use a three position switch so they have a choice of manually going into fail safe so it "auto lands".
If you buy the Naza ESC's they are optocoupled and have no BEC built in. Good luck Pete
May I ask what optocoupled is?
#6 |
#7 | |
Blade Nano CP X, QAV400, Naze32 Acro Quad, Spektrum DX7s |
#8 |
You need to make up a lead that stops the Naza BEC feeding power to the servos and use a separate BEC that feeds power to the servos. I just pull the red lead from some extension leads and feed the extra BEC's power into the leads gong to the servos.
Pete
#9 |
Even one small pitch servo from the NAZA gimbal control?
HC3-SX FBL 10S Trex 600>700ESP, 8FG, HKIII 4035-530, ICE HV120, Outrage HVs Quaternium Spidex, NAZA GPS, EZOSD, TSLRS, 1.3G, 4S900KV |
#10 |
If you avoid a brownout it is worth it.
#11 |
I'm not using the ESC BEC. Would you recommend using that to supply power to the gimbal servo instead of placing the extra current draw on the NAZA? What about the UHF Rx? Is the NAZA BEC cleaner than the average ESC BEC? Thanks for the tip! Makes good sense even if just for insurance in case the servo ever stalls.
I also just remembered I am powering my GoPro from the NAZA too...
#12 |
what if you plug a bec into your receiver? will it back feed through the naza and supply the needed current to the gimbal servos? this all seems crazy to me. cant imagine it pulling hardly any current. havent made it through the manual yet though. still building mine. i would just think that having a couple ports for gimbal servos on the naza that it would be made to handle it.
-trex700n -trex600n -trex500 -trex450 -trex250 ...blade mcx...best cat toy so far. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ...& Aurora9 |
#13 | |
I would use the ESC BEC to feed the Rx, Gimbal, and pitch servo and the NAZA BEC would then be dedicated to the NAZA alone. Makes sense as long as the ESC BEC is just as quiet as the NAZA BEC. Its dead weight unused may as well divvy up the load and put it to use. petedee?
