| X7 Discussion and support of the Gaui X7 |
Have any of you routed the ESC/BEC cables from the front of the heli to the back via the central channel in the frames? I’m concerned about the cables getting snagged on the Gaui/Scorpion motor shaft (XL) as it pokes out the bottom of the lower support bearing. I am running my wires on the outside of the frame and it looks terrible. Currently have mini vbar on the lower gyro tray with the wires coming out the back. This was a mistake as I can't get it neat, thinking of turning it through 180 to better hide the cables. Might do what Matt did, strip out the boom, head main gear, shaft and motor to get the wiring in place.
Goblin 700, Gaui X7, 600EFL, DX8 |
#2 | |
E7 | E5S | E5 Team Synergy | Gens Ace | Scorpion Motors | Progressive RC | Anything Heli |
#3 | |
I'll double check when I get home, I still have it apart from my trip.
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 - All on VBar 5.3 Pro GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster |
Thanks for the pics Rob, they are a great help. Did you plug all the cables into the vbar unit before you taped it to the frame? Is that hot glue on the servo plugs going into the back of the vbar? From the hook and loop tape on the side of the battery bay I take it you dumped the battery frame and are strapping your packs right onto the frame?
#5 | |
I've had to go in a couple of times and change my wiring while trying out BECs, so removing the side CF plate really makes it easy to get in there.
#6 |
mine run down channel along the side, tubed. But i'm alittle paranoid at times and chopped about 4mm off the long shaft. Sits about flush with the bottom of the bearing.
mini v as in in Rob's pics. Hides everything Vas
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx GAUI Field Rep, Team Empire Hobby |
#7 | |
#8 |
I've now turned the vbar around and have routed the bec and esc and sat cables via the central channel. As mentioned before they do tend to sit on one side or the other, none come in contact with the motor shaft.
The only down side to this is that I forgot to go back into the vbar setup to set it to upside down with the wires coming out the front Spun the heli up on the grass and it was not behaving. Had a good poke around and found nothing so I spun it up on the paving in the parking lot. It was never going to end well, my Rail 105 tail blades are now 102mm long. There is slightly more play in the tail gearing but not a great deal. I will replace the tail blades and see how I get on before I swap out the gears. Good job I didn't spin up and punch the collective, I would still be picking up pieces of the x7 out of the field.
#9 |
You should check your v-Bar for alignment. It is slant !!!
#10 |
Yup taken care of that. Took the side frame off and filed a gap for the satellite cables to poke out the side so they don't put pressure on the vbar unit.
