Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-17-2012, 04:49 PM   #1
Phailed
Default Question about the main frame.
Hello. I bought a used trex 550 awhile ago and crashed it a few weeks ago. I broke one side of the main frame amd ordered a new original one from www.flying-hobby.com. The only problem is that the frame I recived is diffrent than the old one. The main diffrences is the angle in the front where you mount the battery mounting plate and the new one is lacking a triangle shaped hole at the upper rear side. The seller told me the old frame was an original one and is seems logic because the old frame looks like the one on the picture displayed on flying-hobby.com ( http://www.flying-hobby.com/shop/car...mm-p-6491.html ).
Is there diffrent original main frames from the Trex 550? Im kinda confused now
Phailed is offline        Reply With Quote
Old 04-17-2012, 08:56 PM   #2
bike mad
welcome to the world of align 550 where things get changed with out any name or prefix,
you have bought a late frame as align don't keep spares for discontinued heli's or parts,
The way I see it you have three choices one is to find some one with an old frame.
or buy another align frame to go with the one you have bought.
or buy two new frames, send the one you bought back and buy a pair of up graded frames, 2mm thick CF, I use tarot frames which I like, they are stronger and cheaper than aligns, they fit well and take a lot of force to brake them, I haven't broken my tarot frames yet even after 18 months and 3 crashes,
bike mad is offline        Reply With Quote
Old 04-18-2012, 12:21 AM   #3
Phailed
Hi.
Thank you for the help.
Old 04-18-2012, 01:22 AM   #4
markleyland
+1 for the Tarot frames, cheap and reliable (thicker)
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 04-18-2012, 03:02 AM   #5
chrismechanic
+2 tarot frames
warp 360-ds92-ds525m-polaris bec-beastx-edge 50 lite-yummy
Synergy E5-castle 100 ice-bec pro-beastx.
futaba T8FG--R606FS/R617FS
chrismechanic is offline        Reply With Quote
Old 04-18-2012, 03:25 AM   #6
jackhsu
Tarot frame is an excellent alternative. The only downside is they are heavier.
jackhsu is offline        Reply With Quote
Old 04-18-2012, 07:57 AM   #7
mtuccio
+3 on the Tarot frames....Very good quality for the cost....
mtuccio is offline        Reply With Quote
Old 04-18-2012, 09:28 AM   #8
Phailed
Seems like I'll have to buy that next time I crash then :p for now I'll just switch out both sides of the frame with the original one i got from flying-hobby.com
