| 4G6 / V120 Series Walkera 4G6 / V120 Series Helicopter Support |
When I learned that the 808 #16 keychain batteries were the same voltage as the stock V120D02S batteries, and that the #16 had a battery plug instead of being simply soldered onto the board, I was inspired.
I'd tried mounting an 808 #11 on board before, but it was too heavy and bulky and made the heli too sluggish. So I wanted to try a mount where I got rid of the keychain body and where the heli battery also powers the camera. One thing that's nice about the V120D02S battery is that it's got two leads coming off of it, and they're in parallel. These are (apparently?) to be compatible with different or older models. But anyway, them already being in parallel meant that part of the work was already done for me. So the only custom thing I had to do was solder together a battery plug for the camera and a female plug for the alternate lead off of the battery. Easy! I just grabbed an extra wall adapter and snipped off the female end. Here are the results so far. Here's my soldered cable. ![]() The V120D02S battery happily powering the camera. ![]() And both the heli and the camera at the same time. ![]() A snug fit... ![]() ![]() Canopy still to be addressed. ![]() And here's a test flight (sans canopy). It's not very clear from the video, but the camera doesn't really affect the handling of the heli. It can still pitch pump pretty aggressively (as much as I dare to test in my house), and doesn't seem noticeably off-balance. I have some remaining sub-problems.
Anyway, I thought you guys would like to see this. I'd really appreciate any critiques or ideas, too. DANCING BACON MAN ![]() Last edited by pennello; 04-18-2012 at 02:05 AM.. Reason: auto youtube parsing wreaked havoc with my links |
Nice!!!
![]() I've seen people mount the entire thing, plastic case and battery and all and your solution is very elegant! Seeing your having done that made me, for the first time, consider putting a camera on my 02S. Very nice! ![]() |
Sweet write up and build! Video looked pretty nice actually... not too much shaking/vibrations.
Do you have a link to the camera? I'd love to try this on one of my D02S birds
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX // // Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) // // EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX // // WK2801 // Spektrum DX4e // |
#4 | |
Pennello, is that were you got yours or did you find a better price somewhere? |
#5 | ||||
#6 |
#7 |
Nice idea! I used the same battery connector to power LEDs.
How about this to mount it in? Cut a piece of polystyrene to this shape so the circuit board slides in and the lens goes into the hole at the end. You could use velcro tape to mount it to underneath of the battery tray. The polystyrene will also help reduce vibrations which is a must do with a small camera. As for wide angle lenses. You could try one of these.. http://www.ebay.co.uk/itm/Jelly-Lens...item56448b776f |
#8 | |
Ok; progress!
First, a indoor test flight video. This is with the canopy off. Outdoor test flight video in the V120D02S videos thread. Ok, now more explanation. I solved all four sub-problems I had remaining. Quote:
Ok, a few pictures! It's wedged in there pretty snugly. Servo tape and velcro prevent the image from vibrating too much. ![]() 3/4 view of cut-up canopy. It took a bit of experimenting to figure out the right parts to cut away so the camera could have a mostly unobstructed view. ![]() Front view of cut-up canopy. ![]() One really cool thing is that it seemed to add an unnoticeable amount of weight. The heli still seemed zippy and agile in FFF and some basic rolls and flips. I think the only two things I'm dissatisfied with are:
DANCING BACON MAN ![]() Last edited by pennello; 05-12-2012 at 09:41 PM.. Reason: cross-linking for great justice |
#9 |
Very elegant. I want to do the same, so thanks for the instructions and pictures! Great!
KR, Henk Blade MCX, FBL 4G6V-2S Xtreme, FBL 4G6V-1S Xtreme rewind, FBL 4G6S-1S Bell 222 Darthdark, FBL V120D02S |
#10 |
Now.. how easy do you think it would be to attach a transmitter for the video, does anyone know of a lightweight video transmuter? also can this keychain camera send live video out?? or does it just record onto the card?
#11 | |
However, regarding getting a video-out signal, I know that the newer 808 #16 models come with a USB adapter for producing VGA out. They do require a 5V DC input, though. It uses a standard servo-style plug. In addition to this, it will still record onto the card, as before. 808 #16 with video-out. ![]() |
#12 | |
should work for u just fine on 120 heli (: |
#13 |
That video is rock solid! I intalled one onto my V120D02s old... by leaving it in the case and taping it under the battery. Very easy, simple and inelegant. It does work but more vibrations than you have, that is awesomely stable.
With the full case, the heli flies fine, still plenty of power but you can "feel" it. Thanks for the vid. John |
