Go Back   HeliFreak > R/C Electronics Support > bavarianDEMON/HeliCommand
bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support
Old 04-18-2012, 10:03 AM   #1
kruizer7
Default Turns Left on Spin up !
Finally I almost have my trex 450 set up with the HC3D . I am using a DX7 TX and 7 channel rx with satelite. I have adjusted about everything I can see, but when I spin the heli up and get light on the skids it wants to nose left. I have checked the tail movement with the stick and its correct,and when I have the heli sitting still I can physically turn the nose left and HC will do the corrective action to straighten it up. I sure could use some good advise here . Thanks !
kruizer7 is offline        Reply With Quote
Old 04-18-2012, 12:27 PM   #2
kruizer7
Default Senior Moment !
Sometimes we get so technical in our minds, we forget to look for the simple obvious issues, LOL . I have overcome the turn left issue. Now its on to the fine tuning !
Old 04-18-2012, 02:09 PM   #3
yosemite
what was it?
yosemite is offline        Reply With Quote
Old 04-18-2012, 02:22 PM   #4
Goldenhour
Sounds like gyro reversed.
600 Align Futaba 14SG
And about $7000 in assorted things.
Goldenhour is offline        Reply With Quote
Old 04-18-2012, 02:42 PM   #5
kruizer7
Default You wont Believe me, LOL
Would you believe not enough tension on the tail belt ? LOL After I took all the wireing back loose and redone it, then did a reset , then set it back up,,,several times. The tail was spinning , but i couldnt tell any difference in the speed. Then I accidently turned the tail rotor by hand about a 1/4 turn while II was checking the mechanics, and heard the belt skip. I put a little more tension on the belt and does fine now. Even had it hovering in the living room. If it wasn't raining I would head outside !
Old 04-18-2012, 04:52 PM   #6
Stanley Speel
I've done worse - ran the belt completely inside out on my gaui X2!!
Sent from my GT-I9100 using Tapatalk
Gaui X5 Formula SK720
Trex 600 EFL Pro AR7200BX
Trex 450 Pro DFC HC3SX
Blade MCPX BL
Stanley Speel is offline        Reply With Quote
