Old 04-18-2012, 11:22 AM   #1
greycat
Question pitch curve/governor
I have a 450 clone and wanted to start using govenor mode. I would like to use 80% throttle in normal mode and use 90% in stunt 1. what would be a good pitch curve for normal at 80% and I am assuming a linear curve for stunt 1 at 90%?
greycat is offline        Reply With Quote
Old 04-18-2012, 02:28 PM   #2
wanderer56
I like Normal PC=40-45-50-75-100 with TC=0-40-80-80-80
IU1 PC=0-25-50-75-100 with TC=80% flat.
IU2 not used
Trex 500-3226-1600, 14T, Koby 90LV, HS-5245MG, DS655, AR7200BX, DFC
Trex 450 Sport-2221-8, 15T, CC Edge 50 Lite, HS-5065MG, HSG-5084MG, AR7200BX, DFC
DX8
wanderer56 is offline        Reply With Quote
Old 04-18-2012, 02:43 PM   #3
greycat
Thanks that helps. I was thinking pretty close to what you recommended.
Old 04-19-2012, 07:17 AM   #4
wanderer56
You can play around with the flat part of the curve you just need to leave some headroom for the govenor to work. Where ever your heli likes it on HS. You may even need to go up 1 tooth on your pinion. Some govenors don't work very well. Align's gov is not known for being one of the greatest on the market.
DX8
