Old 04-21-2012, 08:48 PM   #1
lmcwilli
Default ZYX dead after firmware upgrade
Today I attempted to do a firmware upgrade of my Tarot ZYX 3 Axis Gyro (ZYX20210314) so that I could use the features of the ZYX 3.0 software.
I downloaded ZYX-S3.0EN.rar from the Tarot website (www.0577mx.com).
http://www.kingwjg.com/tool/ZYX-S3.0EN.rar
Using the v3 software, the firmware update ran successfully.
However, now the gyro does not initialize: no lights at all!
It appears that I used the ZYX-S firmware upgrade rather than ZYX firmware (I didn't know there was a difference).
What should I do? Is my gyro hosed?
mSRX, mQX, Nano CPX, BL Nano CPX, BL mCPX, Blade 450X, Tarot 450 Pro FBL, Witespy HT-450 Quad
lmcwilli is offline        Reply With Quote
Old 04-22-2012, 01:39 AM   #2
Mikej
Re-flash it with the latest version for the non-S ZYX http://www.kingwjg.com/tool/ZYX2.5EN.rar
Mikej is online now        Reply With Quote
Old 04-22-2012, 06:24 AM   #3
lmcwilli
The problem is, I don't know how to get the ZYX reconnected to the software.
When I power up, no lights flash on the ZYX. When I press the set button, the red light flashes but then the ZYX goes dark.
Old 04-22-2012, 07:13 AM   #4
ifheli
Is this a ZYX-S or a ZYX ? Did the program open a window at end of upgrade saying something like..."upgrade successful" and did you see a green bar at bottom of PC program? If it did not give a clear message of success then read the the PDF that came in the 3.0 software..
Keith
ifheli is offline        Reply With Quote
Old 04-22-2012, 07:25 AM   #5
lmcwilli
My gyro is a ZYX---not ZYX-S. Yesterday, when I did the firmware upgrade, I wasn't aware that there was a -S model. So, I mistakenly updated my ZYX gyro with ZYX-S firmware. That update process was "successful". I got an update completed message. And, a bar at the bottom confirmed the transfer of so many bytes to the gyro.
The problem is that loading the ZYX-S firmware appears to have hosed my ZYX. My gyro neither initializes nor connects to the ZYX software.
Old 04-22-2012, 07:41 AM   #6
ifheli
OK... The number ( ZYX20210314) you posted made me think it was a ZYX-S instead of a ZYX. My ZYX does not have a number on the side of it but the ZYX-S does..... You could try this program and firmware for ZYX and see if it will connect and then load the firmware upgrade for the ZYX.....
The program is.....http://fbl.net.nz/download/25
The firmware is....http://www.kingwjg.com/tool/ZYX%20ROM.rar
Keith
Old 04-22-2012, 07:46 AM   #7
lmcwilli
OK. I'll give that software a try. But, the problem I'm having is that I can't get any lights on the gyro---not even when I press the set button.
Old 04-22-2012, 07:52 AM   #8
ifheli
When you dowload the firmware, you have to move it out of the chinese languge folder for it to work... Also the FBL program should be able to force upgrade the ZYX without following Tarots instructions..I have never had to do this so far so not sure on the exact procedure.....
Keith
Old 04-22-2012, 08:05 AM   #9
ifheli
There`s lots of information on RCGroup.... One good place is here..http://www.rcgroups.com/forums/showthread.php?t=1568592
Keith
Old 04-22-2012, 08:26 AM   #10
lmcwilli
I would think that I need to connect to the ZXY before I can do a firmware upgrade. My problem is that I can't get a connection.
Old 04-22-2012, 08:44 AM   #11
Mikej
not if you use John_NZ's software that IFHELI linked to, try this
* download the 2.5 software http://www.kingwjg.com/tool/ZYX%20ROM.rar unpack it and load the .bin file onto your desktop
* Download John_NZ's software http://fbl.net.nz/download/25 check that it runs, then close it
*insert the USB dongle, then start the FBL software again
*connect your ZYX (not switched on yet)
* power up the ZYX with the set button pressed - you should get the red flashing light, go to the Firmware Upgrade box, select it and then click on the >bin file that you loaded onto your desktop, then hit the upgrade button - it shoul dnow load the firmware, when it says that it has been loaded successfully power everything off.
* now power the ZYX again - all of the lights should come one - you will need to re-initialise and reset al of the settings.
Good luck,
Mike
Old 04-22-2012, 08:46 AM   #12
ifheli
You should be able to turn on Tx and connect battery... Then connect usb dongle, open FBL porgram, select correct com port, open zyx.bin, and hit upgrade.... I believe these are good steps. I have never had a failure / problem with ZYX`s so I`m not sure of the exact steps... I don`t think you have to hit connect button in the FBL program for this to work
Keith
Old 04-22-2012, 08:49 AM   #13
ifheli
MikeJ steps do sound better... I have never been in this position....
Keith
Old 04-22-2012, 10:07 AM   #14
lmcwilli
Thanks for the specific directions. I'll give them a try.
Old 04-22-2012, 11:57 AM   #15
lmcwilli
Mikej's directions worked! Whew. I was afraid i was going to have to buy a new gyro.
Just in case some other hapless person wanders into this swamp, following is a slight re-write of Mikej's directions---indicating what I actually did.
1. Download the 2.5 software http://www.kingwjg.com/tool/ZYX%20ROM.rar unpack it and load the update .bin file onto your desktop
(I downloaded from: http://tarot-rc-heli.com /ZYX_3_Axis_Flybarless_Gyro_ZYX?filter_name=zyx)
2. Download John_NZ's software http://fbl.net.nz/download/25 check that it runs, then close it
3. Insert the USB dongle, then start the FBL software again
4. Go to the Firmware Upgrade box, click OPEN, browse to the .bin upgrade file (that you loaded onto your desktop), then click OK
5. Connect your USB dongle to your ZYX (not switched on yet)
6. With the set button pressed, power up the ZYX (I used a paper clip to make sure the button is pressed)- you should get the red flashing light
7. While the red light is flashing, go to the "Firmware Upgrade" box, then click on UPRADE. As a result you should see an upload progress bar.
8. When it says that firmware has loaded successfully, disconnect power to the ZYX.
9. Now power on the ZYX again - all of the lights should come one - you will need to re-initialise and reset all of the settings.
Old 04-22-2012, 12:19 PM   #16
ifheli
Good to hear you got it back
Keith
Old 04-22-2012, 12:37 PM   #17
lmcwilli
Thanks for your support Keith.
Old 04-22-2012, 01:29 PM   #18
Mikej
Glad you got it sorted willi - it's frustrating when it's "bricked " isn't it
Old 04-22-2012, 02:32 PM   #19
2Drum
Nothing more true has ever been spoken!!!
Doug
The opinions expressed here are merely that, opinions, so keep your feathers down.
2Drum is offline        Reply With Quote
Old 04-22-2012, 02:34 PM   #20
2Drum
Excellent post
Doug
