Go Back   HeliFreak > For Sale Forums – KNOW your buyer/seller ratings! No Price bashing. Work out price details via PM. > Gas, Glow and Turbine Helicopters
Gas, Glow and Turbine Helicopters *No Commercial Ads - Liquid Fueled Helis Only
Closed Thread
Old 04-22-2012, 11:49 AM   #1
rototiller
Default 600N
Hi guys.
I converted my nitro over to electric and these are the parts I dont need. Looking to let this go complete instead of breaking it up. I am open to trades, what do you have?
Everything is Align.
The good.
Carbon frame with some alum upgrades like, new style elevator a-arm. Great shape, bearings and all.
Os 50, I got the motor with what was stated as 10 tanks. I opened it up and it was clean and wet so no reason to dought a fellow HF'er. I put 6 gallons of 15% threw it. It spent its life with me set to 1950-2000 and 12 deg of pitch. Now theres 3 small carbon patchs on top of piston and none on the head. The side of the piston (pix) looks worse then the top of the piston.
2 in 1, works great
Align pipe, looks/works great
Tork tube tail setup. Everything is in good shape with spare gears and tube.
Align sensor with servo plug on the end (for my multi gov) works.
Home made starter wand for you drill
The bad
One frame plate is 2.0 the other is 1.6mm. I never noticed anything odd in flight. The 2.0 frame is cracked at the radio tray (pix) but holds solid.
The canopy has a chip at the edge (pix) but otherwise new/lightly used.
$325 to your door via pay pal.
ID:	310167   Click image for larger version
ID:	310168   Click image for larger version
ID:	310169   Click image for larger version
rototiller is offline
Old 04-25-2012, 04:53 PM   #2
rototiller
I can break this up if its easier.
Frame, fan, clutch $150
Motor/pipe $100
TT setup w/boom block, gears and tube $80
obo
Old 05-07-2012, 05:33 AM   #3
rototiller
sold
Closed Thread
