Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 04-22-2012, 07:38 PM   #1
Mike2112
Default Deanodizing Heat sink??
Has anyone ever tried to deanodize the Ice75s Heat sink? Is it easy to remove the heat sink from the ESC?
Hirobo Evo .50/Futaba 9C/OS 50 Hyper & Hatori/Radix/GV1/GY401&9254/9252s/Arizona Heli Canopy
Trex 500 FBL/Futaba 8FGS/CGY750/CC ICE 75 & Scorp 1400 16T/Radix/9650s/9256
Trex 450 Pro/Futaba 8FGS/450M 14T/TP Blades/ 3156s/ Futaba GY520&9257
Mike2112 is offline        Reply With Quote
Old 04-23-2012, 02:56 AM   #2
yves200
Desanodizing the heat sink?? with that intention?
yves200 is offline        Reply With Quote
Old 04-23-2012, 07:18 PM   #3
Mike2112
I need to mirror-polish it.
Old 04-24-2012, 02:45 AM   #4
yves200
Ok to deanodizing de aluminium you must be done a solution of caustic soda with whater (1/1 relation), in a 3 or 4 minutes de anodizing surface must be out of aluminium heat sink. Be careful with the soda because causes skin burns.
Old 04-24-2012, 10:03 AM   #5
RC Mike
The anodize coating keeps it from shorting out the two sides of the circuit board. You must make sure that it’s insulated from where it contacts the board and make sure that you still have good heat transfer. If you are not careful everything will go up in flames and the warranty will be void.
RC Mike is offline        Reply With Quote
Old 04-25-2012, 09:27 PM   #6
Mike2112
Oh Crap! Thanks. Didn't know about that.
Old 04-27-2012, 08:45 AM   #7
BaconRaygun
Easy-off oven cleaner.... main ingredient = sodium hydroxide, AKA, lye.
~Outrage~ Fusion 50 (FB) ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team Boca Bearings****Team LYNX Heli Innovations**
The member formerly known as Vicovaludemero
BaconRaygun is offline        Reply With Quote
