Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 07-07-2012, 10:23 PM   #21
gitbse
Lol from all the threads I read here Vico .. you and I seem to have the exact same heli philosophy. You going to any shows in the northeast? We should fly together sometime.
Skookum Support Rep
Mini Protos SK540,Rave ENV SK540, 4525 LE
Runways are for models and wings are for fairies.
gitbse is offline        Reply With Quote
Old 07-08-2012, 04:30 PM   #22
SamCassidy
What about flying different sized batteries? I have a Chrome 2500mAh 35c that is long and skinny and a Pulse 2600mah 45c that is short and wide, whenever im changing between those two LiPo's I usually give it one click of trim on elevator to counteract the change in CG. How else should i do this? I can't change linkages every time I change batteries... I COULD change my subtrim every time, that would be a pain too...
Compass Atom 550: SK540 / DS510 / KingMax 5308MDHV / Castle Talon 90 / KBDD Tail / Mavrikk 515 VST Main
Blade mCpx / Nano Cpx mild BL
- Skookum Field Rep -
The Official Pistol Gang - Mavrikk Rep - ) :>
SamCassidy is offline        Reply With Quote
Old 07-08-2012, 05:36 PM   #23
gitbse
If you are not doing 3d, changing a few clicks of trim to offset batteries will not make a difference.
If you go inverted alot, and fly 3d... all of your batteries should be the same.
Skookum Support Rep
Old 07-09-2012, 09:54 AM   #24
BaconRaygun
I'm goin to a few local FunFlys, probably goin to NEAT fair, and maybe some others if they are not too far. How about you?
~Outrage~ Fusion 50 (FB) ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team Boca Bearings****Team LYNX Heli Innovations**
The member formerly known as Vicovaludemero
BaconRaygun is offline        Reply With Quote
Old 07-19-2012, 03:35 PM   #25
Digger1973
Sokal set vids on the B400 is the same setup on a flared 450. The vids are on HF in the B400 forum if I remember right. They are worth watching if you are starting out.
Sent from my HTC One V using Tapatalk 2
B400(retired)
Mini Titan V1
Radikal G20
Digger1973 is online now        Reply With Quote
Old 07-20-2012, 11:44 AM   #26
gitbse
I'm planning on going to Rochester, and helis over the hudson. Also NEHC phenom, out near boston
Skookum Support Rep
