Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 05-06-2012, 02:51 PM   #21
myrseth
The pinions are for gearing for the target headspeed nothing to do with power. Power is how the motor keeps the headspeeds in pitch changes and power moves.
From what I've seen of the motor it keeps it's rpm whatever you throw at it and does not heat up so you can use the canopy which is a bonus for me as I'm starting to gather dust as ahclem, and start loose orientations without it!
Klaus Myrseth Team Compass
7HV FBL fullsize VBar - 3Dplus FBL fullsize VBar - Atom 500 FBL mini VBar
JR 11X <3 - KBDD
myrseth is offline        Reply With Quote
Old 05-14-2012, 07:18 PM   #22
lazor 22
What timing and PWM for the hobbywing 120 and new motor?? On the box it says 8 khz but I see so many hobbywings going up in flames at 8.
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amain
7HV, Warp, 3D+
Lincoln
lazor 22 is offline        Reply With Quote
Old 05-14-2012, 07:42 PM   #23
agagescu
+1
My HW should be arriving any year now. Inquiring minds want to know.
agagescu is online now        Reply With Quote
Old 05-14-2012, 07:44 PM   #24
belcom
I ran it at 12khz PWM and 18.75 timing. Everything was just a bit warm to touch and no fires.
Compass 7HV, SAB Goblin 700, Minicopter Diabolo, Mikado Logo 600, Synergy E5
RCHeliCanada.com - Compass Model - Synergy - Scorpion - MKS Servos - YGE - Kontronik
belcom is offline        Reply With Quote
Old 05-14-2012, 07:59 PM   #25
lazor 22
Ok thanks will set it to that and see where to go from there
7HV, Warp, 3D+
Lincoln
Old 05-14-2012, 10:44 PM   #26
myrseth
Im currently running 12pwm and 15 timing, will try go down one step on timing. Motor gets a bit hot but hw keep just over body temp
JR 11X <3 - KBDD
Old 05-16-2012, 05:16 PM   #27
agagescu
Awesome, thanks guys!
Old 05-29-2012, 09:05 PM   #28
lazor 22
Ok, I am running this combo @ 2350 with 15T. I don't push it to the limits but I would say I push it harder then the average joe and no over amping problems or anything like that. ESC is not getting hotter then normal either. So you probably wont need higher amp esc
7HV, Warp, 3D+
Lincoln
Old 05-29-2012, 09:08 PM   #29
Rob43
One of the HW positive characteristics is that it just seems to take the pounding and hang in there. It won't power down like Jive might. Of course, that, and 1/3 the price!
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 05-29-2012, 10:45 PM   #30
jrod155
12 and 18.75 for me
esc is warm, and motor is below the 60 deg C burn your hand test.
i learned that at work
below 60, you can touch and hold it
above 60, it's gonna hurt.
Compass 7HV, El Brute, Ice2 120HV, TracX fbl
Compass Atom 500, Ice 100, TracX fbl
TX: Futaba 7C w/ Fr-Sky DHT, Soon to be Taranis
Old Models: X2, X5, TREX(250, 450, 600ESP), WARP 360, 6HV, 450X, bl CO5M MCPX, Genius CP
jrod155 is offline        Reply With Quote
Old 05-30-2012, 08:30 AM   #31
agagescu
You kind of have to do the hand test. I have a IR thermometer but they are not very good at getting temps off of reflective surfaces. The highest reading was 130* after a flight when the ambient was close to 90*. I doubt that. It felt hotter.
I have a few flights on mine now at 12KHz and 15*/14T at 2000 gov and it has a lot of power. Not monster power but enough for right now.
Old 06-04-2012, 05:40 PM   #32
jrod155
anyone try the stock hw governor with the brute yet?
I don't have a tach so i can't confirm this, but, according to the headspeed calc for hobbywing i should use a 81% flat throttle for 1850 headspeed on gov high
but when i spool up, i can tell it's super slow, i have some bad wobbles b/c my heli gives a good shake out wobble when i spool up normally, but i don't think i'm hitting that headspeed.
to confirm, the motor is a 10 pole motor, correct?
Old 06-04-2012, 11:04 PM   #33
agagescu
It is a 10 pole motor.
Haven't tried the built in gov but have heard it's pretty crap.
Old 06-05-2012, 02:16 AM   #34
jrod155
i'm pretty happy with my v-curve, but i wanted to give it a shot.
Old 06-09-2012, 12:21 AM   #35
deniscle
Hello, with the engine compass 570kv and the castle 120HV, I can make no more than 1900 tr in set rpm. I configured poles 8, 12T / 136.
deniscle is offline        Reply With Quote
Old 06-09-2012, 02:15 AM   #36
agagescu
This isn't really the thread for it ...
If you want a higher headspeed, you could go for a bigger pinion. 2050 w/ 13T
http://heli.dacsa.net/MrMelSite/iframe/index.html
