| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Ok guys.. After about 3 weeks of just trying to figure out where to start, I've finally settled on the T-Rex 450 Pro V2 SE Kit. So, before I get to the real question, let me give you some background....
I've been in RC for about 3 Years now. I first tried to go straight into Heli's, and realized very quickly that I needed to get more financially fit for that. So, have been working with Cars for almost all 3 of these years. I know right away that I need a good simulator (Realflight was what I used before) and that I'll need a good TX, that I can use with my later Heli's. I've done a little bit of research and knowing that where I live, It's windy (Kansas), I wanted to got straight into the 450's. Now, the real question. Where is the best deal!? I know which Heli I want. I know it's not cheap, but, might as well save every bit I can. Anyone know any good websites or where to get the best deal? I will probably look for a used TX (DX6i, or DX7s), but want to see if you guys could point me into the right direction for the kit and/or the simulator! I appreciate all of the help..and glad to finally post instead of all of the lurking I've been doing!! |
Try the used heli section here at HF or get in touch with some people at your local club!
VBar T-Rex 250 & 450 * Tricked-out Blade 400 with CopterX FBL * mCP X |
for a sim you cant beat phoenix....its about the best around...for a free sim follow this link.
http://www.marksfiles.net/HeliSim/ tx..i would recomend something in the high end market..futaba, hi-tec or jr. if its very windy where you live a 450 might be a bit small..15mph winds make a 450 a bit of a handfull. bash the sim for hours until you have some control over the heli...most new fliers crash within 30 seconds ![]() good luck
trex 450 pro-fbl-scorpion 2221-8-custom motor mount-beastx-tarot head-beam e4 swash trex 550e-castle 100 ice-bec pro-alloy tail control arm- 550mm blades-beastx-compass 6hv head-2mm side frames futaba T8FG--R606FS/R617FS |
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation |
Thank you! Will definitely give it a shot!
Sent from my SGH-T989 using Tapatalk 2 |
