Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 04-23-2012, 03:43 PM   #1
GeorgeLucas1981
Default Un controllable spinning
Ok so heres the deal, after a slight crash I took my mSR completely apart (every screw) to get to the finer parts of the heli. I also took the time to replace the main frame and skids which needed me to take the tail off the 5 in 1 board and away from the old frame. Having replaced every thing to the new frame and rebuilt as per the explosion diagram it was time to spool up. Having re bound the controller (Dx6i) after crashing as per the manual, the blades turn the right orientation and the tail motor works, the problem arises as I increase throttle, the heli just spins to the left which then tips it off axis and all over the floor like a dying insect. No lift just fluttering all over the floor. Any help peeps is appreciated as usual.
GeorgeLucas1981 is offline        Reply With Quote
Old 04-23-2012, 04:06 PM   #2
Pfloyd
Anti rotation collar upsidedown....linkages should look like picture below.
MCX/MCX2/MSR/MSRX/MQX/C105B/S300/MCPX/S107G/S107C/S109G/S108/S026/S009G/S023G/S102G/S110G/GYROPTER/
AIRRECON/UDI-803/UDI-816A/SYMAX1/V959/JXD-355/052INTERCEPTOR/EYE1/S113G/UDI-U810/
DX7s
USAF RETIRED (1968-1988)
Pfloyd is offline        Reply With Quote
Old 04-24-2012, 04:41 PM   #3
hydro_pyro
You didn't plug the tail motor in backwards, did you?
Modified Blade mSR
UM P-51 Mustang
UM Sukhoi SU-26XP
hydro_pyro is offline        Reply With Quote
Old 04-24-2012, 05:55 PM   #4
deesman
like hydro said you may have plugged it in backwards i did this with my msr and couldnt figure it out until i just tried it for the f of it. funny you would think that that cable would be color coded like the rest are
deesman is offline        Reply With Quote
Old 04-25-2012, 03:59 AM   #5
GeorgeLucas1981
No not plugged in backwards however on closer inspection thanks to Pfloyds photo uploads and loads of head scratching it turns out as I reassembled the mSR I've inadvertently placed the swash plate on upside down. So tonight it will come off go back on and be test flown, results to follow, thanks for all your inputs though it's appreciated.
Old 04-25-2012, 04:10 AM   #6
litehawkdown
do yourself a favour and light it on fire!
litehawkdown is online now        Reply With Quote
Old 04-25-2012, 01:09 PM   #7
petedee
I think you are on to something here.
DJI Naza 330, 450 & 550 hexa, TBS Discovery (Naza-M/5.8Ghz vid link/ET telemetry), KK2 micro hexa and micro quad, Nano Ladybird/Spektrum Hybrid, Nano MQX hybrid.
300X, Trex 450 Pro DFC, mCP X's, mSR X, nano CP X
DX18, 14SG
petedee is offline        Reply With Quote
Old 04-25-2012, 04:40 PM   #8
Liduno
To any one that wants to burn their msr, I will gladly pay shipping if you want to send me your msr..lol
B400 130X MCPX MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED.
Liduno is offline        Reply With Quote
Old 04-26-2012, 02:35 PM   #9
petedee
I am not quite giving up yet but I setup and fly an mSR X, a couple of mCP X's including a brushless version and a 250 and 450 and a couple of quads and I simply cannot get my head around why the mSR is so crap and difficult to even get it to do basic hovering.
It seems there is two choices with the mSR, it either just works and no one really knows why or it doesn't work and no one really knows why.
DX18, 14SG
Old 04-26-2012, 02:43 PM   #10
Liduno
I've had a bunch and I love them for indoor flying and if there's no wind they are fun out side too.
The best thing I did for mine was to cut 2 mm off the length of the blades and tightening up the anti rotation fingers to take the slop out of the links.
Old 04-26-2012, 02:46 PM   #11
Liduno
Another good way to eliminate bad hovering behavior is to keep moving..lol
Old 04-27-2012, 01:54 AM   #12
Pfloyd
The msr was not made for hovering....if you like to hover get a coax...the msr is for flying all over the place, indoors and out..much fun..
DX7s
Old 04-28-2012, 04:35 AM   #13
GeorgeLucas1981
Let's not forget thou its a helicopter and first and foremost basic hovering is essential to transition into forward flight as is it important prior to landing, I know this as I've worked in the back of real helicopters for 8 years now.
Old 04-28-2012, 02:12 PM   #14
hydro_pyro
So, you're saying that your heli spinning? Or toilet-bowling all over the place? Please clarify.
If you're getting hover instability or toilet-bowl effect, you have binding, play or a combination of both.
Remove the rotor blades, and upper pair of links. Verify that the grips pivot free and loose on the spindle by themselves. ANY friction or binding is BAD. Gently try to twist the rotor head and grips gently side to side. There should NOT be any play. If the shaft hole for the screw gets worn or the top of the shaft gets a crack, the rotor head can twist slightly out of phase-- this is bad.
Report back with your findings...
Modified Blade mSR
UM P-51 Mustang
UM Sukhoi SU-26XP
Old 04-29-2012, 01:12 PM   #15
GeorgeLucas1981
It's not TBE it's a rapid left yaw on spool up then it tips over and just flips all over the floor until the throttle is shut off.
Old 04-29-2012, 04:51 PM   #16
petedee
Yep that is what mine is doing.
DX18, 14SG
Old 04-29-2012, 07:37 PM   #17
RCjarvis005
Check the trim on your rudder. Mine was doing that a while back and my rudder trim was all the way in the direction it was spinning. Just a suggestion.
RCjarvis005 is offline        Reply With Quote
Old 04-30-2012, 02:31 PM   #18
petedee
Yes but I can fly many things but this just rolls over and never gets off the ground, can't even do any sort of flight.
DX18, 14SG
Old 04-30-2012, 02:33 PM   #19
petedee
All set at zero, takes full stick right to just get it off the ground a bit.
DX18, 14SG
Old 04-30-2012, 06:14 PM   #20
Pfloyd
Will it fly if you hand launch it?
DX7s
