Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-23-2012, 05:21 PM   #1
Heli man01
Default Vibration on spool up and down
Hey guys,
My 600e pro has an odd vibration at a certain low headspead when throttling up, and when throttling down. What could be causing this? Out of ballance blades, a bad bearing, etc?
-Trex 600efl pro-
-Trex 450 pro V2
Heli man01 is offline        Reply With Quote
Old 04-23-2012, 06:50 PM   #2
satgod
yea mine does to
and you can almost bet its that align motor
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 04-23-2012, 07:10 PM   #3
Heli man01
I don't think its my motor. I wanna say its a bearing or the torque tube. Any other ideas?
-Trex 600efl pro-
-Trex 450 pro V2
Old 04-23-2012, 09:35 PM   #4
Commodore8888
Frequency of the vibe at which headpseeds is very important. Location is needed too.
First thing to do is minimize variables. Take the head off and run it up (you can bench run at 3 to 6s for slower testing speeds). If the vibe is not present, suspect the head/blades. If it's still there but is slower in pulse than tail rpms, suspect main gear, owb, auto gear wobbles, etc. If you find the vibes are high in speed even at lower head rpms, check the tail, then the TT for being straight(I've had ones out of true from the factory).
The motor being out of balance can cause highfreq vibes, but are normally pretty low in strength since the motor has a low diameter of mass compared to the tail. It would have to be bad enough that you would likely see the offset on the motor.
Resident Mad Scientist
E5-S KDE 600XF / 600N 55HZ
450 Pro V3 / Mod 130x / mCPX BL
Mike D--AwesomeRC Hobbies
Commodore8888 is offline        Reply With Quote
Old 04-24-2012, 05:39 PM   #5
Heli man01
all righty then. I will start testing it and see what it is.
-Trex 600efl pro-
-Trex 450 pro V2
Old 04-25-2012, 02:22 PM   #6
jonbailie
Does it run ok when the headspeed is higher? I would start by balancing the blades, and while they're off for balancing, spool it up without the blades to check for vibrations. Out of balance blades can cause vibrations or wobbles at certain (usually slower) headspeeds. There will be some vibration at high headspeeds, too, but certain resonant frequencies can show up while spooling up or down. I'd bet balanced blades would make a big difference.
If that doesn't help, hopefully something will show up when you spool it up without the blades. From there, you just need to run through the things that commodore listed in order to troubleshoot it.
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX //
// Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) //
// EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX //
// WK2801 // Spektrum DX4e //
jonbailie is offline        Reply With Quote
Old 04-27-2012, 10:06 PM   #7
Heli man01
I will try balancing the blades. From everything you all said, it sounds like they are the problem. Will give it a try.
-Trex 600efl pro-
-Trex 450 pro V2
