| Mini CP Walkera Mini CP Helicopter Support |
We all know that stock batteries on Mini CP last only few minutes at best. Which is the best Lipo in others experience, that would give at least 4-5 minutes of solid power. I read about 400 mah battery but I don't want to burn my motor.
Thanks, Aftab. |
I'm currently using the Walkera 350mAh batteries with quite a few recharge cycles already past and no problems so far.
I get a strong and consistent 5 minutes flight time using these compared to the 3:30 minutes I got with the Hyperion 250mAh batts I also have or the 2:30 minutes from the stock batts. The motor isn't stock but it's not brushless either. The batteries I use are heavier though so while one can get a longer flight time for practicing orientations and similar non-energetic types of flight, the overall performance isn't up to doing much in the way of 3D. One other issue though is that these batteries are a little larger than the original batteries so they won't fit the battery cage but I cut the battery cage off of mine soon after I got it in favor of holding the battery on with a strip of velcro. Between batts, I let the motor cool down for about half a minute and the temperature seems to remain within a fairly safe range. |
Im getting about 3 1/2 out of the Walkera 240mahs.
Bit of a delayed addition to the thread but how are these?
http://www.hobbyking.com/hobbycity/s..._Pro_100_.html I know you've got to reverse the terminal ends somehow as they're meant for nine-eagles - I am aware they use the same connector but different polarities. Anyone try these lipos yet? If so how did you reverse the leads? Thanks Spykez
Prôtos mini's - trying desperately not to hit the ground... |
#5 | |
#6 | |
Thanks again!
