| Kasama Helicopters and Upgrades Kasama Srimok 90 Helicopters and Upgrades Discussion |
Hello,
I am doing a maintenance of my Faifa and the bearing of the pinion bearing block drive feels notchy. I have tried to heat the block in the oven to replace it, but it would not come loose. Does someone know how to remove it? |
Did you crash it?? I had the same Problem after a major Crash. Heated it up in the oven to about 180°C
for 15min but it wouldn't come out. Then i noticed that the bearing was in the block crocked and it needed to be pressed in first so it was strait and fully seated and then i did the oven thing again and it went out like nothing!! Good luck!! If it is strait in and the oven is not hot enough then use a blow torch and really heat it up and it will fall out!! the block will easy tolerate 450°C! Use the torch only on the side of the block not to heat the bearing directly!
Helis:; Kasama Srimok ECO - V-Bar; Kasama Faifa LRH V-Bar!!! Radio: MX-20 Hott |
Hi Stallion,
Thanks for your answer. I did not crash it, so I suppose that the bearing is strait, I am upgrading it to LRH, and doing some maintenance after 4 month. I do not have a blow torch right now but I will buy one and try it. |
Or use a gas stove.
/Henrik
Hookmaker Kasama Srimok 90, Kasama Srimok 90E, JR Vibe 90 SG, JR Venture 90, JR Vibe 50 3D V-bar, Bergen Intrepid Gasser, Vision-SX 90 (x 2) MSH Protos "Monsterheli", HDX-450 |
