Old 04-25-2012, 11:33 AM   #1
clough42
Default To keep going after a scare, or call it a day?
This weekend, I attempted my first vertical stall turn with my 450. I rehearsed the stick movements in my head before I attempted it. It turns out that was a really smart thing to do. It went perfectly. The tail snapped around to vertical, locked in and I pulled it out just as pretty as could be.
After flying a bunch of banked figure-eights this morning, I decided to try it again, but skipped the mental rehearsal. The heli was coming right-to-left in front of me, I pulled back on the elevator and stalled it vertically, and then, instead of snapping the rudder, my thumbs decided to try a banked left turn. I pushed the aileron over about 45 degrees to the left, started drifting the rudder around to coordinate the imaginary turn, added collective to maintain altitude, and then wondered why it was coming straight at me, vertical, nearly tail-down.
I got it punched over and headed away from me and started breathing again. The bark off the bottom of the rotor disc under full collective at close range is a religious experience.
I remember watching it fly away across the field, at a crazy nose down attitude and thinking, "I guess I could try to save it." I got it back under control, brought it back and set it down in one piece.
What do you after a scare like that? Do you pack it up and go home, or continue flying? I decided to fly another battery, just to regain my confidence, and it worked out. But the voice in my head was telling me that was a bad idea.
clough42 is online now        Reply With Quote
Old 04-25-2012, 11:37 AM   #2
wbefield
I continue to fly, but only try stuff that I am comfortable with and come back to the skeery unfamiliar maneuver another day. I also try to keep the heli at a distance in the first place, so If things don't work out as planned, hopefully I won't have any hair raising moments.
William
Alees Rush 700-Kosmik 160A + KDE 700XF-495
Synergy N5C & E5-600
Protos 500
wbefield is online now        Reply With Quote
Old 04-25-2012, 11:37 AM   #3
tommeke
continue flying and try the trick again...and crash
tommeke is offline        Reply With Quote
Old 04-25-2012, 11:41 AM   #4
rcflier1
fall off the horse, get right back on, by next week the fear will build
rcflier1 is online now        Reply With Quote
Old 04-25-2012, 11:44 AM   #5
rdlohr
Yep, keep flying as long as you have packs to burn.
On the other hand, I've gone out and found myself mentally fatigued to the point where I am sloppy and not really enjoying myself. Then I pack it up.
Rick
Helifreak, the place to be!
Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X
My products, flown by top pilots around the world, like you!
rdlohr is offline        Reply With Quote
Old 04-25-2012, 11:49 AM   #6
seanh
power down, turn tx off and clean my drawers. Chill with a cold drink for a few then go back and fly...just a lazy flight for no 1 battery. For no 2, battery, step it up a bit.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910
seanh is offline        Reply With Quote
Old 04-25-2012, 12:12 PM   #7
Jermo
Keep flying but go back to basics. It sounds like your fingers still aren't 100%
Jerry Moore, AMA #878954, IRCHA #2988
Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL
Ok, you can fly...but can you HOVER??
KISS = Keep it simple stupid (to maximize fun and reduce costs!)
Jermo is offline        Reply With Quote
Old 04-25-2012, 12:22 PM   #8
dannylightning
i keep going, after about 10 seconds i forget all about it.. when i first started i would set down for 10 or 15 min before i flew again after i had a close call. eventually they wont phase you any more
dannylightning is online now        Reply With Quote
Old 04-25-2012, 12:32 PM   #9
koppterx
i think (because it has never happened) that if my scare involved the potential for serious injury then i would call it a day. if the worst result is a good story and momentary weak stomach it has never stopped me. sometimes i'll break out something more relaxing - glider, plane, 700.....
converting nitro into noise since the 70's.
koppterx is online now        Reply With Quote
Old 04-25-2012, 12:32 PM   #10
deca
If I spook myself I generally call it quits. It usually happens after I've been flying for a while so I chalk it up to mental fatigue and decide to quit while I'm ahead.
I know right? That's why I'm always working to keep my 500 closer and closer to myself as I improve
Blade 400 || mCPx || Trex 500 ESP 3GX
learned basics in winter '09, started again in winter '11 after year or so hiatus
currently working on: piro flips and inverted circuits
deca is offline        Reply With Quote
Old 04-25-2012, 12:54 PM   #11
fastone93
I try again immediately as long as I know what I did wrong...
If it goes haywire and I don't know why, I hit the sim again first!
Trex 700 dfc (OS 105HZ-R, Hatori Pipe, MKS HBL950, Futaba CGY750, MKS HBL980, Rail Mains, Rail Tail Blades)
fastone93 is offline        Reply With Quote
Old 04-25-2012, 12:58 PM   #12
AcidDrink
I had my protos do a tail stand about a meter in front of me on take off (FBL system went bit crazy). I thought I was going down, but reflexes took over, continued to fly as normal for the rest of the flight .
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote
Old 04-25-2012, 02:15 PM   #13
Elgyn
Keep flying or land until the adrenaline is gone and then keep flying. Fear is a useless emotion and can get in the way of rational thought.
Elgyn is offline        Reply With Quote
Old 04-25-2012, 02:29 PM   #14
Varc
When I say, "Just one more time." Is when I should quit.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Rakon NCPX-TDR, DX7. Rakon Rep.
Varc is online now        Reply With Quote
Old 04-25-2012, 02:33 PM   #15
Tridztan
Don't give up. There is always light at the end of the tunnel. I'll come good for you sooner than you think. Keep going.
Dave
Sent from my iPhone using iFingers
Dave
Blade mSR & mCPX | Storm 450 | TREX 450 Pro | TREX 500 ESP | Spektrum DX7 + Phoenix & SIMSTICK | Futaba T8FG Super
Tridztan is offline        Reply With Quote
Old 04-25-2012, 02:33 PM   #16
Mr.Andersen
When something like that happen i start flying slow and safe until i feal comfortable enough to try out something new again.
CopTreX 450 SE V2, Pro..... real bastard.
Logo 500 3D FB
Blade mCPX
Mr.Andersen is offline        Reply With Quote
Old 04-25-2012, 05:13 PM   #17
drakonis
if it does not scare ya your not flying it! scareing your self is part of the learning curve. just take a little break. go over what you did wrong. mentally correct yourself for the next flight. did you do a stall turn right up in front of yourself? i would only do them at the ends of my flight area im using. never in front of myself. go ever your maneuvers in your head then go fly them. pretty soon youll have a nice routine you can put together and fly.
drakonis is offline        Reply With Quote
Old 04-25-2012, 05:14 PM   #18
Blayd
Last time out, on my 14th pack, ( I fly 15 packs between three 500's...) I had an "incident" and one of the birds went in on its side. Second crash in 18 months.. on a newer bird.. bummer....went and picked up the crippled heli, checked it out.. leaned against the tail gate, took a breath, a sigh, a drink of water, .....loaded pack 15 and threw my HC500 around. For me.. a scare or a crash, has GOT to be taken in stride these days.....
My first real crash on a 500 a year and a half ago, really spooked me.. I spent all summer long hovering and stuck.. no progress....no more of that....my skills are much better, and my hands are learning.. so a crash happened.. learn from it.. figure out what happened.. get in the air and break through....
Trex700N2E
Trex500ESP (Belted)
HC500SE All flying Spartan, CC100A, CC20APro, Hitec 5245MG, Futaba 9257, Walkera Devo 8S, KBDD, i2!
Blayd is offline        Reply With Quote
Old 04-25-2012, 05:26 PM   #19
aralan
Keep flying. It's important not to let yourself continue to be intimidated by your scare, crash, or whatever the case may be and end up holding yourself back. If I crash in the middle of a flight I'll pull the batteries out, stick them in the other machine, and finish the flight. Preferably right back in to whatever I messed upon the last flight.
A Main Hobbies
aralan is offline        Reply With Quote
Old 04-25-2012, 05:30 PM   #20
clough42
Thanks for all the replies.
That's pretty much what I figured. If I stopped at that point, with that being my last experience for the day, I'd be fighting the psychological weight of that my next time out.
So, I took a breath and flew it off. I'm glad I did.
