| Atom 7HV Compass Atom 7HV Model Helicopter Discussion |
#21 |
Thunder Tiger has a OWB lube they have been selling for years. Don't know what is really in the little flip top plastic container. I do know that I can't find mine
A Main hobbies stocks it or used to.
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900 |
#22 | |
the parts manual is wrong with some parts i have noticed that part number is a set of thrust bearings the parts i used were 60-15245 and 60-17265 and that cured my clicking but taht was after a crash they was fine before so i think they got damaged then
goblin 700- goblin 500 - tdr 700 -logo 500 - gaui nx4 Blade mcpx bl and 130x climb out distribution |
#23 |
I changed those bearings and clicking is gone. Thank you very much.
Warp 360 - Brain | 7HV - Brain |
#24 | |
Sorry GG. Not yet. I emailed all of our information concerning design, speeds, and operating modes to the engineer at Molykote. He replied today. He's working on it, and I would hope to hear back soon.
= R To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. b43 = Team Compass Support |
#25 |
Hey Rob, you ever hear anything back on this? I had emailed Dow about it a while back and got an email they would look into it but I never heard anything back.
Team Synergy VP Racing Fuels Team Scorpion |
#26 |
Nothing more. I tested the Thunder Tiger plastic gear grease (Molykote 30ML). I really didn't care for it. I went back to Sil Glyde. It's very possible that Molykote will have an alternate suggestion. Hope it's not something that comes in a minimum quantity of $500 worth of product. I think there is a potential to open up the clearance of the pulley on the one way hub.since it's bolted to the lower half of the one way drive. Mine simply hasn't worn. Maybe some lapping compound to wear some clearance in. I have read the Goblin owners using WD40 to be a mild abrasion agent to lap the gear mesh in. This is a possibility. I will need to study the assembly the next time I have it apart to see if there's a more apparent remedy. For now, it's not really significant. Probably near 200 flights now and counting, so who knows.
#27 | |
Hello Rob43,
Have noticed that even if I remove the main pulley, and try to rotate the lower end of the auto-rotation sleeve (09-7103 ), while holding stead the main gear, the auto-rotation sleeve remains equally sticky towards the freewheeling direction of rotation. So, no matter if main pulley is on the auto-rotation sleeve fixed with the two set screws or removed from it, the resistance I detect is the same; honestly, am really wondering how this will autorotate with such frtiction. Also, did another test and held the main pulley fixed in my hand and attempted to give the main gear some momentum to with my other hand to see how much it can freely rotate and it was not more than 50-70 degrees before the main gear stopped. Is this normal behavior and I should expect that once the main pulley is "loaded" with belt tension, the whole thing will rotate smoothly? Thank you very much, Spiros Quote:
#28 |
Spiros
All i've done on both my 7's is take the one way apart, wipe the dirty lube off, re apply tri flow and flown. Both machines auto down from 10ft to 500ft with no problems at all, this is with some friction as you say.
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep |
#29 |
What type of Triflow should be applied to the one-way bearing? I have got Triflow Clear Synthetic Grease that I use on my thrust bearings. Is this the one or are you talking about a silicone based synthetic oil, rather thin one?
Thank you. |
#30 |
Just the thin oil. The one in the pencil applicator.
Sent from my iPhone 4s using tapatalk
#31 |
i used triflow on mine.. i just looked and its the superior dry lubricant, not sure if that is the right thing to use on a one way or not.. i did not realize it was the dry lube that i had till just now..
my one way makes some noise, all bearings are ok and working just fine..
GAUI X5. = pure awesomeness youtube.com/dannylightning facebook.com/dannylightning1313 |
#32 |
"Just the thin oil. The one in the pencil applicator. "
That is what I use on all of my one-way bearings.
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
