| Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum |
#21 |
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e HeliDirect, Team iKon, GrandRC Last edited by OnTheSnap; 05-05-2012 at 10:17 AM.. |
#22 |
The info in the sticky will help most pilots. I don't fly that hard but I was stripping front gears every few flights until I found out my front TT gears had a LOT of play... and after sanding the block (instructions in the sticky) I've never stripped one since.
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. Last edited by Slyster; 05-04-2012 at 08:49 AM.. |
#23 |
#24 |
well well well .........
I had first flight with modified of a tail rotor and total 8 flights of my F50 for last weekend. I fell smoothly and perfect. One observe, Tail Gain Stop A and B on V Bar 5.2 pro are unequal which I mentioned before the tail rotor shaft a little shorter I not sure whether this is effected to V Bar value or not. Anyhow, I happy for my F50 reborn |
#25 |
OTS: Are there other issues that need to be addressed, or are you just generally referring to the fact that other random issues can occur?
-Jay To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#26 | |
- Gear strips too easy, this is serious case for me due to I never founded before for other helis. - Elevator arm broken during constituted due to tighten the nut. - Ball bearing flanged attached frame for control rod of elevator set moved after a few months.I put an epoxy glue to fixed. - Tail case twisted, I just pin it by bolt. - Tail rotor set / plastic grip link broken, I need to purchased an Aluminum Tail pitch slider set just only for 1 no. of small plastic grip link due to no separate part for sell. Therefore, please don't make it broken. - Rust on your link........ By the way, I much like behavior of F50 it's easy to control. Fly by hope with Fusion 50.... ![]() |
#27 |
is there a gap between the bearing and the shaft? see pic
#28 |
#29 |
I thought you were supposed to put a shim between the end of the shaft and the crown gear (on the left side of your picture) so that the 2 crown gears would mesh better. The gap that xfactor pointed out should not have anything to do with the shim.
Current Fleet: TRex-700/500/450/250 Vbar, Logo 600SE/600/500 VBar, Outrage Fusion 50/G5 VBar/FB, Blade mCPx x 2 |
#30 | |
It's worth noting that the Fusion directly inherited it's gearing system from the Velocity which was spec'd for 2100RPM max. Insane headspeeds and power can quickly overcome the stock setup, so you need to be vigilant if you want to push the machine hard. I have looked at many Fusions for beginner/intermediate/advanced pilots, and when they fly in dusty conditions (off dirt) I see unusually fast wear on the tail gears. So flying off of dirt has for sure caused many early failures. If you fly off dirt, check the gears every day and replace immediately if there is more than a tiny bit of gear lash. Also note that with a little dremeling you can fit on a QuickUK or Align tail hub/grips. These come equipped with 3mm bolts and are much more tolerant to abuse and can handle higher RPMs without failure.
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e HeliDirect, Team iKon, GrandRC |
#31 |
Thanks, that's what I was wanting to hear about. I'm not a hard enough flyer to stress the tail much, and I normally fly around 2200.
I think I may still look into the align or quick uk tail grips and hub.
#32 | |
Logo600 has 2.5mm bolts as well and I've seen many failures there too. 86mm or larger tail blades I would recommend 3mm bolts.
#33 | |
Thank guy, I will check carefully which side need to be shim, this is not original part so can't follow previous info. It depend on the mesh and gap of 2 gears. The gap according to Mr. xfactor pointed for me need to fill otherwise the gear will carry the lateral force along tail rotor shaft during you play left rudder (Heli rotate CCW), it should fit and lock in tail box. Last edited by the_wuth; 05-08-2012 at 03:21 AM.. |
#34 |
#35 |
Although 2200 RPM still need to check well for mechanical system, my F50 I fly idle 1 only 2050 RPM and idle 2- 2150 RPM run on 550kv with a 13T pinion. Some time only I use idle 2. But still happen..........
