Old 07-19-2007, 08:51 PM   #1
aamwood
Default Anybody has issue with the oneway bearing ?
Mine was broken twice already. Is it because I installed it wrongly ?
aamwood is offline        Reply With Quote
Old 07-19-2007, 08:53 PM   #2
drummer5140
No, I have ran 6 gallons so far with no problem.
drummer5140 is offline        Reply With Quote
Old 07-19-2007, 09:10 PM   #3
aamwood
Then something is wrong with mine. It happened to my friend too. Both of us using G10 after market frame. Is it because of that ?
Old 07-19-2007, 09:32 PM   #4
Filby
There is a known issue with the oneway. There is now a new sleeve available from Align that MAY fix the problem:
One-way Bearing Shaft H60018
Filby is offline        Reply With Quote
Old 07-20-2007, 04:03 PM   #5
mrj
The newest issue of rc heli says they had problems with the one-way locking up.Must be a problem if the heli that the magazine gets had issues after a handfull of flights.
mrj is offline        Reply With Quote
Old 07-20-2007, 05:37 PM   #6
aamwood
I have used white lithium grease on my bearing, I hope it will stop the locking up. Looks like Align should work on this issue .
Old 07-20-2007, 06:59 PM   #7
3DBatixkid
It will still stick, depending on how hard you fly. I have tried all kinds of different lubricants, and get MAYBE 2 flights to a bearing. This is with the new sleeve as well. Servo grease has been the best so far, but still locks. I can break it free after the flight though.
Zak West
3DBatixkid is offline        Reply With Quote
Old 07-21-2007, 01:40 AM   #8
aamwood
Just an update. I put white lithium grease on the bearing and it solved the problem. Went through 4 tanks without an issue. Just try it it guys. Hopefully it works for you
Old 07-22-2007, 05:59 AM   #9
G MAN
There are 4 600N flying with no issues at all,they are all using the stock plastic with magnets and the stock one way brgs. They are also using the 2 in 1 regulator also.DOUG
G MAN
NO ES MI CULPA
G MAN is offline        Reply With Quote
Old 07-29-2007, 04:11 PM   #10
Whirlybird
Two out of two at out field locked up immediately. Both one way bearing say "Germany" on the end. I had a problem with my Rappy 50 V2 early on but these Trex one ways lock up so tight you can hardly pry it loose with two flat blade screwdrivers.
Whirlybird is offline        Reply With Quote
Old 07-29-2007, 08:18 PM   #11
aamwood
Yes, mine was lock up twice and my friend's was too. But, once we put the white lithium grease, the bearing is perfect. I think the bearing is good just lack of lubrication.
Old 07-29-2007, 08:32 PM   #12
Whirlybird
What type lithium grease are you using ? Is it in a tube or a spray can ?
Old 07-30-2007, 02:34 AM   #13
aamwood
I am using a spray can. Check it out at : www.wd40.com
So far so good.
Old 07-31-2007, 02:56 PM   #14
captcasper7
I just finished my 5th flight and the one-way has locked up
Trex 600N Pro
Trex 600N Sport
Knight 3D
captcasper7 is offline        Reply With Quote
