Old 04-26-2012, 09:04 AM   #1
beans07
Default YS Check valve on OS engine?
I am having some issues with my OS55 HZ-R engine going lean when unloaded and tok the check valave apart and it looks to be out of round.
I have a couple of YS check valves laying around.
So has anyone used a YS check valve with an OS 55 engine? Is it really critical to use the OS branded one?
Synergy E7 ~ Logo600SX + 600SE ~ Synergy E5 ~ Synergy N5C ~ Mini Protos ~ Futaba 14SG
beans07 is online now        Reply With Quote
Old 04-30-2012, 02:29 PM   #2
Elgyn
don't think it would make a difference. all it does is stop tank pressure from leaking back into the crank case. Run it for a bit and the check the tank pressure. if you have pressure than it should be fine
Elgyn is offline        Reply With Quote
Old 04-30-2012, 03:53 PM   #3
beans07
Thanks for the reply mate. I have decided to Swap out the reg and backplate for a non regulated one of the standard 55 that I had spare and will rebuild a motor with it as a spare when needed.
The check valve I was using the silicon flap was way out of round. I don't know if this has been the cause of my issues or it is the reg itself. The engine it was in has never ran good since I got it a year ago.
